head gasket size
Old June 9th, 2018, 06:25 AM
deadeyejedi's Avatar
head gasket size
what size head gasket bore should i buy for my .030 over 455 build ?would like to go with cometic and part number would be helpful.i assume .030 over on the gasket as well ? i would like the .027 thickness to maintain my targeted compression ratio.
deadeyejedi is offline
Old June 9th, 2018, 10:02 AM
after doing some research i think i answered my question .cometic offers a 4.200 bore .027 thickness head gasket for the 455 olds. if my stock engine with a 4.126 bore was bored 0.030 over my new bore should now be 4.156 ?i assume going larger with a gasket bore size would be better than going smaller.
Old June 10th, 2018, 04:42 PM
BillK's Avatar
Correct. One thing that a lot of people don't take into account is the amount of chamfer your machine shop put on the top of the bores. Even a .030" chamfer adds .060 to the bore size when choosing a gasket. In your case you would add .060 to your bore size for a final size of 4.206" Most of the Cometic gaskets don't seal right at the id of the gasket so the 4.200 one should be ok. To be sure measure the od of the chamfer and then call Cometic and ask them to be sure. They are very decent to deal with on the phone.
BillK is offline
Old January 27th, 2020, 06:54 PM
B964's Avatar
Replacing head gaskets on a 455 with stock bore size. Any problems using Mr Gasket 5788G? They are listed as being 4.230 bore size and .038 compressed thickness.
B964 is offline
Old January 28th, 2020, 04:46 AM
cutlassefi's Avatar
Nope, I use those all the time.
cutlassefi is online now
HitTheHole
November 25th, 2013 04:31 PM
coppercutlass
October 25th, 2011 04:38 PM
valhalla
May 30th, 2011 04:07 PM
defiant1
March 30th, 2011 09:22 PM
Joel
March 7th, 2011 10:45 AM
Quick Reply: head gasket size
