Engine shaking at idle
I replaced the radiator and had the harmonic balancer rebuilt and reinstalled, and painted the intake manifold while on engine (removed carb and other linkages and bracket and taped everything off), and now the engine shakes at idle. Set dwell, timing, idle fuel mixture, doesn't really improve. Any ideas? Carb was rebuilt, but was rebuilt and run before changing balancer and radiator and painting, and was running very smoothly. I'm thinking maybe the carb is flooding? There is also wispy smoke that comes out of the carburetor vents while running. Thanks for your help!
Could be your rebuilt balancer is out of balance. pay attention to the frequency of the shaking. Is it at crank speed or half crank speed. the balancer or a out of balance problem will cause a vibration at crankshaft speed/rpm, while a ignition or fuel problem will cause a will cause the engine to shake at half crankshaft speed as the cylinders fire every other revolution.
I thought of that too... The thing is, I sent the balancer out to be rebuilt, and he aligned the outer ring to stock specs (inline with the crank keyway), so I wouldn't *think* that's the issue. It looks to be the correct balancer for the Toronado 425 (the "half moon" balancer). The only way I could see it being incorrect is if the previous owner had put a 330 balancer on the car, which I *think* has a different counterweight (correct me if I'm wrong)
Before that you should put a vacuum gauge on the engine and see what the vacuum reading is at idle. Also look for any loose or mis-connected hoses. Verify ignition timing. Verify spark plug wires didn't get crossed. Again, what got taken off when you did all this work?
1964 is the only year that the 330 balancer is different due to the one-year-only driver-side water pump inlet. If your car had a 1964 balancer on it, you'd never have been able to set the timing in the first place.
Hey all, so I haven't been able to work on the car very much lately, but I found the source of my problem earlier today. I thought I'd post it up in case someone else has a similar problem. I feel stupid for not checking this out in more detail before, but a vacuum line had come loose in a spot I hadn't even thought to check, because I never touched it when I painted the manifold. It was at the vacuum tee under the driver side hood hinge where the headlights and I presume heater controls get their vacuum from. Thank you all for your help, car runs real smooth once again.
