Engine Dimensions needed
I'm in need of the crankshaft centerline to "China Wall" measurement.
Specifically, I have a 67 400. But obviously the 425 and 455 should be the same.
I've looked all over and can't find it online for the Big Block Olds. My car is still together/running, and with everything being so tight, I can't take a measurement that I would actually trust. Hopefully someone has a short block or even a spare block just sitting around and can get me that measurement.
Thanks in advance
Thanks in advance
I have a 455 block up on my milling machine and I am getting right around 10.285 That should be within .005 or so. I can measure it a lot closer once I finish decking it and getting it off the machine.
Thank you,
red&blue442
November 27th, 2011 12:12 PM
