Eagle H beams hitting block... 455 build
Has anyone had to clearance the block for there Eagle H beams? I did a search but could not find anything. Mine are hitting the block.
Yes everytime. You don't need to remove much though. And I use the thickness of a 8" black tie wrap to gauge the clearance between the block and the rod bolt.
