Dual Quad Intake 455 Oldsmobile
I think the only company that manufactures dual quad intakes for Oldsmobiles is Offenhauser.
http://www.offyparts.com/
Actually, Edelbrock USED to make a dual plane, dual quad intake for a BBO. I had one on a 455 and with a pair of Carter 500 cfm carbs and progressive linkage, the car would easily get 14+ mpg (while being aggressively driven). They pop up on ebay occasionally. I'd certainly use the Edelbrock before the Offy. The single plane Offy uses very flat runners. I suspect (based on exactly ZERO hard test data, by the way) that a modern air gap single quad intake would make more power.
fast67vellen2o
August 12th, 2012 06:53 PM
67Olds442X2
December 11th, 2010 09:38 PM
