Coolant in oil
Coolant in oil
Hello,
I am finishing Toro 1966 , engine rebuilt and assembled, seems to be correctly.
but,
after pouring coolant into the system and making a few turns from the starter without start the engine, I noticed that the liquid was mixed with the oil. the engine is in emulsion, the level has doubled.
new gaskets.
after removing the valve covers, I noticed drops of pure coolant on the springs and housing.
and got through the valves to the cylinders.
I suspect it's getting through the intake manifold
Any suggestions ?
but,
new gaskets.
Any suggestions ?
Did you use the turkey tray intake manifold gasket? I've always had difficulty getting those to seal properly. Don't use the rubber end seals that are provided. Instead, use Right Stuff gasket maker:
Also, you can cut the turkey tray from the side rails and ditch the turkey tray or you can get an intake manifold gasket that just has the side rails. Use blue/black RTV at the corners and around the water jackets and use red high temp RTV around the exhaust ports.
Unfortunately, the new gasket is in accordance with the instructions and the coolant is leaking again from the plug in the oil pan. I poured the fluid without the manifold below the holes and it started to drip
I know, the engine was disassembled and reassembled by me, I didn't notice the cracks. But there may be some that are invisible or in a place like this. So hopefully it's a pump or head gasket. I hope ........
EightyEightCut
July 6th, 2012 07:05 AM
