Camshaft engine 425
Camshaft engine 425
boys
I need your help to understand what may have been the problem or the cause of this, one of the camshaft lobe wear and lifter also the other 15 are ok.
I did brak than 20 minutes at 2000 rpm and put the grease with zinc for the assembly of the camshaft that Melling gave me in the box
and after 5 hours of this total is the result
Is the camshaft OK??? It could be just a faulty lifter that wasn't hardened properly. For it to fail that quickly it would have to be something drastic. Maybe some of the other guys have other ideas.
thanks
It being only 1 of the 16, you'd think that the 1 lobe or more likely that the 1 lifter would have been the problem, like a mfg. flaw, as "66" said. If you contact the cam/lifter company, they'll ask you if you f/ sure lubed that lifter/lobe, ask about the condition of the block in that area, about any dirt of any kind that could have been in there, etc. What brand was the cam and lifters? I'd contact the mfg. right away.
Possibly w/ a good enlargeable picture of the lobe, lifter, and block area, someone could give you a "real professional opinion" of what the real problem might have been. I don't mean some blow-hard, but maybe someone good who does machine work, like that guy in Buffalo, New York, or even Dick Miller or Joe Mondello's shop. Not that it's such a mystery, but getting info from someone who may know "right off the bat" what happened/occured here. Good luck.
I think a flaw lifter and were not the company but do not remember what was Melling
thanks for help
Do I see a heavy wear pattern on the lobe to the left of the one w/ the bad lifter? Do any of the other lobes on the cam show a heavy wear pattern? If that cam shows an excess wear pattern from the little bit of time you have on that engine, I'd call the maker of the cam. It shouldn't show a heck of alot from the little time you ran that engine.
Did you prime the oiling system before startup? Did it fire right up or did you have to crank it for awhile? I know you used lube, but what kind of oil did you use? How was the lifter preload on that valve? Was it the same as the rest? Did the lifter fit in the bore with the ability to rotate? No burrs or anything in the lifter bore?
BTW this is not uncommon. Did a SBC a year or so ago with one bad lobe and lifter.
Cutlassefi, Do you not see a heavy pattern on the cam lobe to the left of the one that went bad? What was the reason f/ the bad lobe/lifter on the SBC you did? Just a mfg. flaw?
I agree with the above comment that it looks like a lot of wear on the other lobs as well. Something is amiss here. Was the engine pre-oiled with a drill and a shaft before starting?. Or is this the signs of a bad cam from the factory the made it.
I checked the lifter ran well in the seats and went around with anti-friction oil.
I removed the burrs after grinding and have washed for many hours to assemble everything and I have done before mounting oil into the cylinders by hand.
I checked the lengths of the valves several times and turn on the engine before I rotated out of gas, then 20 minutes at 2000 rpm.
I do not know what may have happened, maybe a lack of material?
I washed very well and then oiled
maybe wrong?
The cam even has a wear pattern where the bearing rides. Did you spin the oil pump and get oil to the top end prior to turning the key and starting it, like was asked acouple replies up?
Did you say that the cam looked like that when you took it out of the box?
look here I've done better.
oil pressure was perfect
the problem is resolved.
The camshaft is controlled by a correction and the material was handled at the surface and had a failure.
I bought a new camshaft with lifters Clevite new, then I have done the run for 20 minutes at 2000 rpm with oil and additive ZDDP, now is the perfect ..
http://www.youtube.com/watch?v=GUWAwg84XzA
jhoppeolds
August 21st, 2014 05:26 PM
joepenoso
January 31st, 2013 09:50 PM
