camshaft break in oil & lube !!
Hi all. i have bought a new Lunati camshaft for our 67 442 car i ran my thread last fall with the gear change over from 3.31 to 3.91 results, the cam seems to be the culprit from what i have been told and do believe myself, so in the spring here iam going to put the new cam in i have done this a couple times before, i do run 10w40 brad peen oil in it since the motor has been it it about 800 miles now since new rebuilt, this is the combo i was going to use for breaking it in, 6 pack 30W BRAD PENN GRADE 1 GREEN BREAK-IN MOTOR OIL High ZDDP FREE SHIP
Moly Zinc ZDDP Extreme Camshaft Grease Assembly Lube Flat Tappet Cams And Lifter
Well what do you all think ???
Here it is !
SKU
10420501LK
Hydraulic Flat Tappet Cam. Good cam for high performance street or pleasure ski boat applications, has good low end and mid range torque and HP. Needs 2500-3000 RPM stall converter, headers, 9:1 compression ratio and 3.73 gearing. Good idle. ;Advertised Duration (Int/Exh): 285/300 ;Duration @ .050 (Int/Exh): 228/235 ;Gross Valve Lift (Int/Exh): .496/.496 ;LSA/ICL: 110/106 ;Valve Lash (Int/Exh): Hyd/Hyd ;RPM Range: 2600-5600 ;Includes: Cam & Lifters (#71951-16)
SKU
10420501LK
That's good to hear no lobe problems. Sounds like you're going for the most camshaft without going to full roller rockers. It is a hassle changing a camshaft with the engine still in the car. I've done a few over the last 53 years since the first one. I've used similar grinds, I think you'll be happy with it. If not, some times you have to love the one your with. Lol.
JM 18-20 H 260 266 216 226 .488 .496 112
good luck and let us know if your happy.
2. I thought Brad Penn was out-of-business. Old stock? Seems like Brad Penn was sold in 2015 and the branding and bottle design was changed. https://penngrade1.com/performance-p...nal-green-oil/
3. Looks like some idiot is home-brewing "moly ZDDP" grease in his basement, and selling the stuff on eBay. I should sell eleven-foot poles for products that shouldn't be touched with a ten-foot pole.
