Bad seals...can I still go?
I hope I don't **** anyone off here, but I am wondering if I can run my 455 with a slight leak in the front and rear main seals? As I was working on my floor pans today I noticed oil runs from both seals. They are small, not even dripping on the floor yet. Engine had sat for 20 years plus, so I suppose it is not a surprise. I just really want to enjoy it a summer before I go all in on a full resto.
Thanks,
Bob
Thanks,
Bob
Most all Oldsmobiles will need to be paper trained especially ones that have sat for years. I blame the issue on the rope seals that oldsmobile used till the the end of the rocket era. It may get better as time and mileage increase but don't bet on it. It doesn't sound like you really have that bad of a problem anyway..... Tedd
Why would a small leak **** anyone off here? Maybe if you park in someone’s freshly paved driveway, I could see annoying someone.
As Joe mentioned, chances are every Olds engine seeps a little oil somewhere. Unless its waving huge puddles, don’t worry about it.
It doesn't "**** me off" but it aggravates the crap out of me I hate oil drips on the garage floor and especially on my concrete driveway. The 307 in my Wife's Riviera leaked from the rear main seal from when the car was about two years old. It got bad enough that I had a drip pan under it for the last 10 years or so. When I rebuilt the engine 2 years ago I used a two piece rubber seal and so far it has not leaked a drop. Has about 15K miles since I did it.
I always worry on this site that someone will be upset because I am not doing things the "right" way. Over the years I have worked on quite a few cars and every once in a while I touch a nerve and get someone all fired up about my lack of knowledge or ability. Just gunshy I guess. I though maybe people might think it is stupid to risk wrecking it. I am glad I can still try to get it to the point I can enjoy it this summer. Seems the perfect tool for social isolation.
Thanks everyone.
Bob
Thanks everyone.
Bob
Bob,
Neither the front or rear crank seals are pressurized so theuy won't suddenly rupture and dump all the oil damaging the engine unless it is run out of oil over time.
The leaks may even lessen with use.
Drive and monitor the leak and the oil level frequently. If it gets bad then stop driving it. Also watch for any excessive oil on an exhaust pipe that could be a fire hazard.
If you have questions don't be concerned about hitting a nerve. Your question is a valid one in your circumstance.
Good luck!!!
Good luck!!!
There's 'snake oil' products that may alleviate leaks somewhat for awhile. The front leak can be more easily fixed by removing the timing chain cover and replacing the seal. The rear main seal leak will require removal of the engine. Some shade tree experts can remove the oil pan then the rear main and snake out the upper seal with a piece of wire with the engine still in the car but I think thats a lost art. Especially dragging the new one back into place.
Exactly, which is why parts are aluminum with machined surfaces. Fewer gaskets are used now, mostly sealants in between timing covers/oil pans. Any gaskets are rubber with crush prooofing or fit into a grove on one of the al. parts.
Exactly, so many overlook this. Everytime I get an equinox/terrain with a 2.4, if the pcv is plugged, the rear main seal will push out. I often estimate a 2hr repair to re and re the intake and repair the pcv, they don't believe me and drive away. Soon after it's back on the hook with oil flowing out the rear. A 2 hr repair becomes a 2hr plus a 10hr repair.
