Adjustable Rockers
Adjustable Rockers
Is anyone using the Comp cam adjustable rocker kit SKU 1442? I have a set but no push rods. Wandering if the push rods that came with it worked, or did you need to order different size? . Comp told me they are 9.654 in length in the kit, and I can order just rods, want to know if the size works?
I just put this rocker kit on mine. The pushrods that came with it worked fine for me, but may not for you application as cutlassefi eludes to.
Pushrod tool is $20 from Summit, worth every penny.
