90deg vacuum nipple on distro vacuum advance canister
Old August 21st, 2017, 10:07 AM
ReallyWildStuff's Avatar
The '77 403's stock distributor has a vacuum advance canister with a 90' turn in the hard vacuum line - thus the open end of the vacuum gallery in the canister points mostly towards the A/C evaporator (instead of the firewall).
The distributor I have on the 455 has the more-typical "straight" vacuum port (pointing towards the firewall). In fact I had to cut this metal nipple down to size so the 455 would fit in the '84-B Body car, and the vacuum line would clear the firewall...
Please help me locate a replacement vacuum advance canister with a right-angle vacuum port.
ReallyWildStuff is offline
Old August 21st, 2017, 11:53 AM
I have not seen a replacement vac advance can with the right angle fitting. The original distributor on my 67 Delta has the right angle. Why can't you take the can off the 403 distributor?
joe_padavano is offline
Old August 21st, 2017, 03:37 PM
Nothing is stopping me from swapping the can from one distributor to the other. I just thought I'd possibly save some time by buying something new.
Old August 21st, 2017, 04:29 PM
Understand. I just haven't seen a 90 deg version for sale new unless it is an (expensive) NOS part.
Old August 22nd, 2017, 06:35 AM
classicmuscle442's Avatar
My '70 442 has a 90 degree plastic fitting on vacuum canister.
classicmuscle442 is offline
oddball
November 16th, 2016 04:04 PM
ziff396
August 10th, 2014 04:47 AM
defiant1
August 4th, 2014 09:15 PM
pcard
February 11th, 2013 05:09 PM
Magna86
March 27th, 2012 03:57 AM
Quick Reply: 90deg vacuum nipple on distro vacuum advance canister
