71 CS 455 with Performer/Qjet NO OAI
Looking for some input. Currently have a dual snorkel air cleaner assembly that is set up for 2 breathers. Options as I see them now:
1- breathers in each valve cover and an intake mounted PCV
2 - breather on one cover and PCV on the other and cap the hole in air cleaner
3- breathers in each valve cover and no PCV
Do one of these options clearly stand out as a better choice for performance?
1970-72 Cutlass 442 W-31 Outside Air Intake Air Cleaner Rubber Plug KE Marking | eBay
One other cat skinning idea. I drilled a hole in back side of oil fill tube, used generic Mr Gasket grommet in the tube to accept PCV valve. Dual valve cover breathers. I partially retract the valve so long neck funnel goes past the grommet when pouring oil.
