495 Stroker BB
Old April 23rd, 2019, 07:06 PM
cutlassefi's Avatar
495 Stroker BB
Not sure if I should put this here or in the High performance section as it's going in a '55 Holiday Coupe. Pretty Cool.
Eagle/Mahle Stroker kit, .060 over
Edelbrock heads, out of the box
10.0:1
RPM intake, center divider cut 1.5"
QF/Brawler 850 Carb
Pertronix Billet dist
Custom Lunati Hyd roller
Canton Pan and HV pump
J&S Halo
Cloyes Billet timing set
Comp Cams 1632-16 Rockers
5/16 Restricted pushrods
Thanks.
cutlassefi is offline
Old April 23rd, 2019, 07:29 PM
OLDSter Ralph's Avatar
I am sure that 55 Olds will open some eyes.
OLDSter Ralph is offline
Old April 23rd, 2019, 07:58 PM
72 Olds CS
RetroRanger's Avatar
Nice you can put that right in my car !!!
RetroRanger is offline
Old April 23rd, 2019, 08:50 PM
RandyS's Avatar
Just out of curiousity, what would a motor like that cost?
RandyS is offline
Old April 23rd, 2019, 09:07 PM
Phantom Phixer
Charlie Jones's Avatar
That horsepower will make that 55 a REAL rocket !
Charlie Jones is offline
Old April 24th, 2019, 05:14 AM
cutlassefi's Avatar
Approaching 14k.
Old April 26th, 2019, 07:23 AM
DROLDS707172's Avatar
495
Didn't think out of the box edelbrocks could support that kind of displacement or H.P.
DROLDS707172 is offline
Old April 26th, 2019, 03:32 PM
cutlassefi's Avatar
There are other ways to make horsepower besides just improving airflow.
Old April 26th, 2019, 04:21 PM
VORTECPRO's Avatar
Mark
Why does this engine drop oil pressure as RPM goes up?
VORTECPRO is offline
Old April 26th, 2019, 04:25 PM
cutlassefi's Avatar
Originally Posted by VORTECPRO
Mark
OK so it dropped 3 pounds from the start, and then stayed at 67 for the duration. If you want to say it dropped then fine.
No matter what I do you’ll try to find fault in it so I will no longer be answering any of your questions moving forward, on any post, at any time. Thank you.
Old April 26th, 2019, 04:28 PM
VORTECPRO's Avatar
No matter what I do you’ll find fault in it.
Just curious what causes the oil pressure drop. On a good note not one of my 496s ever had 660 TQ @ 3500 RPM, nice work.
Old April 26th, 2019, 07:39 PM
W30
truckman5000's Avatar
Are you guys looking for a dick measuring contest?.
I've been seeing you 2 go back and forth for 3 years.
Just come off it already.....
It's like oh, I banged a broad at see level and it took 1 minute...then oh well I banged the same broad at the same weight and we went up skiing in the Rockies, my dick shrank and her **** got looser... but that's not the case, my dick didn't shrink because I was in Texas last week and the humidity got to the wrinkles and I'm fine now. The girl is ok now, now let's talk at the walfull house and get a custard pie. Ahhhhhh noooo.....a custard pie...you talk that **** on me on another forum and ****....ohhh..naw...you paint a engine before heating it up?... I bet you both do😂
truckman5000 is offline
Old April 27th, 2019, 08:24 AM
oldsmobiledave's Avatar
Congrats on another fine BBO build.
oldsmobiledave is offline
Old April 27th, 2019, 08:30 AM
okie88's Avatar
Another great build. Thanks for the specs. I sure would like to see some pictures and info on the 55 after it gets installed.
okie88 is offline
Old April 27th, 2019, 08:53 AM
TripDeuces's Avatar
Cam specs?
TripDeuces is offline
Old April 27th, 2019, 12:49 PM
cutlassefi's Avatar
Originally Posted by TripDeuces
Cam specs?
Sure George no problem. 243/247@.050 on a 110, in at 105.
The lobes are from two different lobe families that I’ve never used together before. Seemed to work pretty well huh😉
Old April 27th, 2019, 01:35 PM
495
Mark, what was the actual lift on that cam? Doesn't sound all that big, but made some impressive numbers!
Old April 27th, 2019, 02:56 PM
cutlassefi's Avatar
Near .600 on the intake and .580ish on the exhaust iirc.
Old April 27th, 2019, 06:08 PM
EightballZ's Avatar
good work mark!
what would be the (max.) healthy HP/TQ rating on that rotating assembly and .60 over, with the edelbrocks modified accordingly?
EightballZ is offline
Old April 28th, 2019, 11:41 AM
Bremer's Avatar
Impressive, congratulations.
Do you think a larger carb would have extended the top end to higher rpms?
Bremer is offline
Old April 28th, 2019, 03:34 PM
cutlassefi's Avatar
Yes my first choice would’ve been a true 950 but it actually did better than I thought it would with this carb.
Old April 28th, 2019, 03:36 PM
cutlassefi's Avatar
Originally Posted by EightballZ
good work mark!
Wgen you get over 600 it’s time to do more for strength.
Old February 2nd, 2021, 04:13 PM
Maple.Ridge.BC's Avatar
My first post- I stroked and dyno'd my first motor build today
Hi everyone. I like reading the posts. Today I dyno'd my engine. I put the eagle stroker kit in it for the 495 cubes. Dyno sheet attached. I'm happy.
Maple.Ridge.BC is offline
Old February 2nd, 2021, 09:15 PM
cutlassefi's Avatar
👍 build specs?
Old February 2nd, 2021, 09:32 PM
Cutlass efi you are a legend on this site.
Well I did the 495 stroker kit as you know
- Intake is the edelbrock aluminum air gap
- heads are the edelbrock 65015 rpm performer
- hydraulic roller cam. Specifically the howards 4/7 swap with 233 duration int/exh @ 050 lift, lobe separation is 110 degrees. Advertised duration is 286
- i went with 1.625 rocker arms instead of the 1.6
- American racing long tube headers to 3" exhaust
- the dyno used a 750cfm carb but I am actually rocking the sniper efi with the hyperspace distributor....the dyno guy was ademant that this would add 20hp since he didn't really spend too much time tuning today with the carb...the main point of dyno was to check the block for leaks.
What else do you want to know?
It's got a rocking sound system and some cool copy cat factory chrome wheels but they are 17x9's on the back and 17x8's up front.
Its a fun toy I also did electric cut outs on the exhaust.
The headers were sent for ceramic coatings today after the dyno run. My car is in the backround.
Old February 2nd, 2021, 09:35 PM
This was the old 455 I had in the car. I sold it with everything included, distributor, intake, carburator etc and used the fund towards to new motor.
Old February 3rd, 2021, 07:49 AM
72 Olds CS
Looks like a great build maple ridge! Nice numbers!
Old February 3rd, 2021, 09:18 AM
Jeff Stout's Avatar
Great HP and Torq numbers.
Jeff Stout is offline
Old February 3rd, 2021, 03:46 PM
cutlassefi's Avatar
I’m not sure about that but thank you very much!
I was going to mention your air/fuels were all over the place. That hurt you as well as only having a 750. The carb I used was actually an 880 and I wish I had a 950, it would’ve made even more power.
The carb and cam limited your hp for sure but the tq is very respectable, nice job. Should be lots of fun!!!!
Old February 4th, 2021, 07:49 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Nice build and a gorgeous car! Have fun keeping tires on the back😉.
olds 307 and 403 is offline
Old February 4th, 2021, 08:22 AM
  #31
ctosiflying's Avatar
Sweet build Mark! Any video on this build? Love to hear it.
ctosiflying is offline
71 OLDS
July 7th, 2020 04:56 PM
cutlassefi
January 29th, 2017 10:55 AM
815Cutlass1972
July 16th, 2016 01:56 PM
young olds
February 28th, 2015 01:07 PM
1978 Oldsmobile Omega
June 15th, 2014 07:23 PM
Quick Reply: 495 Stroker BB
