455 vs 425
455 vs 425
I just bought a 425 I was looking for just a 455 block but didn't pass on a deal. The guy took it apart all part and was in great condition and put back in one piece. I know the Chevy 454 vs the 427 the 427 is the best and Pontiac a 455 vs a 428 the 428 will out run a 455. Even a olds 455 vs the 425 the 425 will out run a 455 Olds. All cams and intake and carbs being the same. What are the views on a 425 Olds motor ?
Gerald
PS
My brother runs a 425 parts in a 455 block for better cam selection never blows a engine.
Gerald
PS
Gerald
PS My brother runs a 425 parts in a 455 block for better cam selection never blows a engine.
Gerald
2. The 425 is a shorter stroke engine but same bore as.455. I would think the 425 will buzz up in RPM's well. The 455 longer stroke has more "swinging mass".
3 The 455 will have more torque.
......Just my two cents worth
Ralph has pretty much nailed it. All 425 cranks are forged. Nearly all 455 cranks are nodular cast. Piston compression height is different, along with rod length. 425 rods are 7.000", 455 rods are 6.700". Other than the lifter bank angle, they are pretty much the same. You can swap the reciprocating assembly from one into the other.
Fair point, Mark. I was thinking of swapping OEM parts, not stroking it even further.
Heavy cars need the torque more than they need the higher RPM limit.
A longer-stroke engine can be faster/quicker than a shorter-stroke engine depending on weight, gearing, tire size, etc. The shorter-stroke engine is not automatically "better".
On my next Olds engine build I'd like to try a 425 myself.
" Heavy cars need the torque more than they need the higher RPM limit"
I think that depends on what the car is used for, and how the car is setup, An Oldsmobile is aways cylinder head limited, small bore, which demand small valves, combined with small cross sectional port area, IMO the shorter stroke could help, I'd like to find out.
Dude it ain’t rocket science(no pun intended), it’s simple physics. If you have limited induction capability as you mentioned, guess what, a smaller engine will spin higher because it’ll take longer to use up the available air. I’ve pointed that out on here a hundred times.
Example, 30 years ago when NASCAR started with restrictor plates, the teams immediately went from 358ci engines to 331’s in the hopes of keeping the revs up. NASCAR said no-no and made them go back to 358’s.
I my self and my Brother Ron Nickels race the 425 for years and like it better than a 455. I raced my 70 W-30 455 with a 73 Mopar 440 I out ran him till I reached the 1/4 on the street and ran out of engine then the 440 just keep passing me up after I was done in RPM's. Think out a 427 Chevy and 427 Ford and a 425 Olds don't you think they are better for racing than a 454 Chevy 460 Ford and a 455 Olds or Pontiac ? My Brother runs a .060 over bore 455 Olds block with 425 pistons rods and crank.
Gerald
Gerald
Gerald
Gerald
A 440 head is similar in flow to a Olds, but heres the difference, a 440 bore is bigger which allows bigger valves, advantage Mopar. A production 440 head worked over can flow around 290 CFM @ 28 inches, same with a production Olds head, but both have a small cross section. Now when you look at a BBC production head worked over now your looking @ 380 CFM, with a much bigger cross section, which will support bigger than 427 cubic inches. When I think about a 425 Olds with a production Olds head I can't see why it wouldn't run similar to a 400 SBC which would run hard with a 290 CFM head. My 71 Buick is a prefect test bed for a engine like that. Always looking for a virgin 425 core.
A BBC peanut port head is a 1974-1989 small port smog head used on trucks, typically they will flow in the 230 CFM @ 28 inches bone stock, many people talk very bad about this head and say never use this head. My ported street peanut port heads flow around 306 @ .550 lift @ 28 inches after porting with a 2.190 intake valve.
