455 Oil pump shim and pick up screens
Old October 1st, 2015, 06:10 PM
72 Olds CS
RetroRanger's Avatar
I have a melling m22f oil pump, a stock rebuild 455 w original oil pan and a few questions
1. can i use the stock original oil screen and pick up w this pump ? or see #2
2. melling sells two press in pick ups 22fs and 22fs1 i cant see or tell any difference between the two is there a difference and what is it ?
3. what is the best way to press in the pick up screen ? just push it in by hand ? any loc tite or anything on it ?
4. and lastly should i shim this oil pump some old threads showed many people shim the pump one measurement i saw was .150 which is about 3.81mm is that good ?
any advice on these questions would be appreciated.
RetroRanger is offline
Old October 1st, 2015, 06:38 PM
cutlassefi's Avatar
Looks like the fs1 is for a Toro.
Shim it about .250 only if you opened up your bearing clearances. Otherwise imo leave it alone.
cutlassefi is offline
Old October 1st, 2015, 08:08 PM
72 Olds CS
ahh OK now that note on 22-FS makes sense (FWD = Toro)
thanks for your help
anyone help w this ?
Old October 1st, 2015, 08:34 PM
This is not to be construed as contradicting Mark, but I shimmed mine with a ¼" nut (or was it 10mm?) and my relief pressure went to 60psi, but my engine DOES have loose clearances.
Please note that increasing the oil pressure and/or volume requires the engine to do extra work, so doing so will slightly decrease engine output and fuel mileage.
MDchanic is offline
Old October 2nd, 2015, 04:25 AM
cutlassefi's Avatar
What is the best way to press in the pick up screen ? just push it in by hand ? any loc tite or anything on it ?
Put the screen in a vise then tap the oil pump onto it with a mallet. Mark the location then spot weld it to ensure it won't come out.
DeepBlue91
March 10th, 2015 03:31 AM
olddaz
June 22nd, 2014 08:36 AM
blakes7
May 3rd, 2014 09:58 PM
davebw31
July 14th, 2013 05:02 PM
Stevec
March 28th, 2012 05:24 PM
Quick Reply: 455 Oil pump shim and pick up screens
