455 dipstick
455 dipstick
I bought a 455 chrome dipstick on ebay for my 72 455 what should be the correct length? ive seen a couple different numbers also if not what is the oil capicity on a 72 455 does the year matter for the length or capacity?
thanks
chris
thanks
chris
With stock pan and filter it's 5 qts. The easy solution here is drain the oil, change the filter, fill with five quarts, run the engine briefly (to fill the new filter), let cool, then check the level on the new dipstick. Scribe a new mark as necessary.
There is no gasket. The dipstick tube must be pressed into the block. If it is very loose, then I suspect you have not hammered it down into the block. The formed ring on the tube mus sit against the boss on the block.
There is 3 ring/ bumps on the block, the first bottom one easily slides in the block the second seems possibly a hair bigger than the enging block's hole then the top ring which im guessing is the formed ring your talking about.
dantecl
October 27th, 2013 02:50 PM
