455 all stock wanting to upgrade
Hi,
Do you think buying the edelbrock complete top end kit is good It includes heads,intake manifold, cam is a good way to go then buy those those Thornton headers and edelbrock 750 carb any thoughts
mike
mike
I am not an expert engine builder but from my experience, an engine build is an entire package or you are tossing money away. I would not throw that much money into a top end without rebuilding the bottom to match. Trying to add power to a 50+ year old bottom end is not a good idea in my opinion.
My vote would be keep your existing carb, install a manifold, and use a more modern camshaft. The edelbrock cams are very outdated. Unless they have modified their cam grinds profile to keep up with the airflow of their heads, your going to be disappointed. Talk to Mark about a custom cam.
if the engine is sound (good compression, good oil pressure, and acceptable leak down) bolting on some go fast stuff won’t hurt anything. If the engine is tired, why bother?
my vote would be keep your existing carb, install a manifold, and use a more modern camshaft. The edelbrock cams are very outdated. Unless they have modified their cam grinds profile to keep up with the airflow of their heads, your going to be disappointed. Talk to mark about a custom cam.
If the engine is sound (good compression, good oil pressure, and acceptable leak down) bolting on some go fast stuff won’t hurt anything. If the engine is tired, why bother?
