Lucky find & buy yet again! 1968 olds 442 Turnpike Cruiser?
Been my year for rare oldsmobile finds... In feb found that 1967 B07 optioned Olds Cutlass Police Sedan loaded w/ factory high performance options... While not as rare as the big block B07 I did find & purchase a running, 1 owner, 69k original 1968 442. So far everything on the car checks out as #s matching 442... Vin matches 400 big block, "34487" on vin & data plate etc. car is all original except for a cheap 80's spray over & old gabriel shocks. car has some pretty strange options for a 442. most notably a factory 2bbl carb mounted on a stock cast iron intake w/ an "H" letter code casting #388625. Car also has a stock "O" 10 bolt ring, 12 bolt cover diff w/ an R2 stamped on the axle tube which denotes 2.56 open gears, 4 wheel manual drums, factory "oldsmobile stamped" mud flaps on all 4's, no ac. KK code (Aqua mist) paint,
Black interior w/ buckets & floor shift th400. Purebred Cali black plate car Fremont Build, bought & been in SoCal since new. Oh yeah its a sports coupe.
So How do I determine if this is infact a rare optioned 68 Turnpike Cruiser? 2nd I've heard this option was kind of rare... Does anybody know the production numbers of the Turnpike Cruiser option? I know the 442 sport coupe option for '68 was a little over 4k but haven't found any info on TPC optioned cars. As always Thanx in advance! Will shoot & post pics this weekend
Marty
Marty
Wild About Cars has all kinds of info for you.
Look in the assembly manual:
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
And the SPECS booklet:
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
btw: thanks Kurt i'll check it out on WAB. ive found a ton of good stuff on there
Marty
It's still there, right?
The only other place would be the Protecto-Plate, which you seem to have good luck finding, and maybe the build sheet or broadcast sheet- maybe.
Does it matter?
Put the square air cleaner on and voila' it's a TC car.
The exhaust heat stove and pipes would be nice, but they are a little harder to find than the air cleaner.
i've been super lucky... right place right time. the B07 police optioned '67 Cutlass was a once in a lifetime find. spotted the rare car by accident driving in a residential area saw it someones open garage w/ a for sale sign on it. you can read about it on here. these guys helped me out a lot when i was trying to verify all the rare high performance options. the best moment came when i found the original protecto plate matching all the high performance options to the car. before that find i knew absolutely nothing about oldsmobiles... but since then i've been on this classic oldsmobile search finding frenzy... searching classifieds, wrecking yards, swap meets etc for rare olds stuff. like myself most classic rodders i've met are either into CHEBS or FRODS.. some MOLPAR.. most have know clue about olds. they usually let the oldsmobile stuff go cheap because they have no clue what it is or what its for. even at the Big 3 swap meet this year i spent 2 days there bought some 15" buick rallys but saw almost nothing oldsmobile related. maybe olds stuff is a little harder to come by or maybe less demand. even at the wrecking yards... i've seen a mid 70's Monte engine & car completely stripped down.. on the same row of cars a 73 cutlass w/ an almost complete 455 w/ th400 trans & diff complete. like i said i think most people just don't know what it is so they pass it by & leave it for me to find.
Marty
Congrats on the find. IIRC the driver's side '68 Turnpike Cruiser "X" exhaust manifold has a different casting number on it VS. the "normal" 389269 unit. Here's my uncle's "sapphire blue" Turnpike.
I got a 68 TPC.Mine is a hardtop,but the options are very simular to your car.
This following is from memory.
The R2 rear axel is uniqe for TPC.
The engine has low comp. pistons.Two barrel carb.
TH 400 trans version,think it is OH is also TPC only.If you have this trans and the VIN derivat on it match the car ,you got a TPC.
Think the intake manifold on mine is a J type.Not sure on this.Will check it tomorrow.
In 1967 it was not a 442, in '68 it was,and therefore came with the 442 badging. The only way to tell in '68 (cosmetically) was to pop the hood to see the 2bbl air cleaner.
Mine has the same intakemanifold as yours 388625.
The old faq site dont have much to say about this manifolds.
Far as I know the 68 TPC is identical to a regular 442 exept from the drive line.
Build for cruising down the highway at a lower rpm.
398625 "H" casting for '68 [-70?] BB 2-bbl
Casting quality often makes it hard to get the digits read right.
Oldsmaniac
October 27th, 2023 05:25 PM
