First Year for 455?
First Year for 455?
Just pulled the trigger on a '68 442, which is reported to have the original 455 Rocket motor. I was under the impression the 455 wasn't available until the 1970 model year, other than Hurst models. The seller claims it is the original numbers matching motor, and it has a red block. Looking at the wikipedia page for Oldsmobile 442 it makes it sound like the base 442s all came with 400 c.i. motors. It's not a deal breaker for me as I do want a 455, but can anyone confirm is any 442s in 1968 did come with the red block 455 motor?
You are correct, no 455 in the 442 until 1970. The exception as you noted is the '68-69 H/O. The vin derivative on the pad below the #1 spark plug will tell you if it matches (it won't). Post pics of your new wheels when you get the chance.
The seller is either uninformed or lying. Be afraid, be very afraid. You may find that it really is "numbers matching" - and a G-block 400, not a 455. It also begs the question of what else has the seller incorrectly claimed about the car.
Block casting
Casting is 396021F so definitely a 455. Will have to get serial number when I pick it up to confirm as the chart above shows it could be from a number of different years. Pictures forthcoming!
Just wishful thinking . I'm still hoping to find the build sheet in my 72 Cutlass to prove that someone changed the VIN from an "X" W30 convertible to a "K"Cutlass just to save on insurance costs 45 years ago
OK Fellas, got the car home and have some info. block stamp is a 30M, so looks like a 1970 motor. Has a QJet carb and, Edelbrock Performer Intake, and E stamped heads. While I am glad it is a 455 the car is an absolute dog here at my elevation (6500-7000 ft) in Colorado Springs. It is a TH400 tranny and is just incredibly sluggish. The shop I bought it from said they put a nice cam in it (either Iskey or Edelbrock) and I wonder if that has anything to do with it. I am not joking when I say a Prius would smoke me. Is it possible the carb needs to be completed re-jetted or at least tuned, along with some timing touch up to have some respectable power? I'm trying not to panic yet but this motor is gutless the way it sits. Somebody please talk me off a cliff...
You begin to understand my skepticism.
Yes, it's a 1970 motor, and the "E" heads are consistent with that. Unfortunately, you have no idea what, if anything, was done to it. It's entirely possible this came from a 2bbl Delta 88, with small valves and low compression. You also have no idea of the condition of the motor - mileage, wear, etc. Certainly a compression test is in order. What is the carb number? What is the distributor advance curve? What are the exact cam specs? Unfortunately you don't know what you have, and apparently this shop doesn't either.
By the way, yes, you will likely need to rejet the carb for the altitude at a minimum. Are the plugs looking sooty?
Ha! Yes it is the shop that claimed it was the original motor. Plugs look good. Will a compression test help me understand what compression ratio the heads are, or just that I have good compression? I can get the cam specs and any other info (even if I need to do some tear down myself) if that will help. Anybody know of a good engine tuner in Colorado Springs?
I would start by checking the distributor: both timing and points condition (if it has them).
If the timing is severely-retarded or the points are shot, then the engine will be way down on power.
Unfortunately you have no idea what's inside that motor. Unless the shop can provide hard documentation as to what exactly was done to it, you're just guessing. A properly built and running 455 should impress you. Do you know what gears are in the rear end?
