70 442 Started, drove 200 yards and stalled. Won’t start.
I’ll preface by saying I’m new to carbs and an older car so trying to self teach as best as possible. I am very mechanical. Race cars that I built. Fix my own BMWs. Just no carbs yet. The car is new to me and since having it I have driven it a bunch. It lives on a trickle charger and has a fresh battery.
I went out of town for 18 days. A friend started and let it idle a couple times while I was gone.
Was going to take it to pool with daughter today. It fired right up. Backed it out of drive way. And at first stop sign in neighborhood it stalled. Wouldn’t restart. Let it roll down hill to house. Tried a few more times. Nadda.
Got it pushed into garage and same deal. It doesn’t “sound” like it is trying to start. Just cranking. Not sure what could have happened to have put miles on it. Instantly fire and then stall.
Gas gauge reads full full but not sure it’s 100% accurate. Going to get some gas and carb cleaner. See if it will turn over.
Where to start abd check? Thanks, everyone.
Check for fuel and check for spark.
What type of distributor does it have? Original points, electronic points conversion, GM HEI, aftermarket HEI, or ???
Knowing which system it has will determine the troubleshooting steps for ignition issues.
*UPDATE
I learned the fuel gauge is wildly inaccurate. I drove it a bunch and my friend had it run a couple of times while out of town. I didn't really pay attention but once I popped hood since I had more time I noticed the fuel filter(or what I believe it to be right before carb) was bone dry. Went to get some fuel and some starter fluid. Put in a few gallons. Tried and nothing. Fuel filter was half full and I could see fuel did go in at the carb. Starter fluid cranked up and died. second try runs great! Let it warm up. Idles. Revs. Etc. All good!
So... questions.
1 - Where is the lead or how does the factory gauge receive signal? Or is it a lost cause?
2 - How many miles can one drive on a tank so I can start to just go off that until I can fix.
3 - Aftermarket gauge to monitor this kind of thing(fuel level)?
If it is pegged full you probably have an open circuit. Remove the wire that runs to the fuel sender stud at the tank or at a connector in the trunk. With the key on and engine off, touch the wire (use a jumper if you need to) on the car side of the harness to ground. The Gauge should go to "E". If it does that rules out any issues from the point you touched the wire to ground, all the way to the gauge. Its probably a bad fuel sending unit inside the tank.
Also anyone have the 'range' I should be seeing as for a full tank?
An open circuit makes the gauge read beyone Full, towards the HOT light.
The wire goes through a grommet in the trunk near the latch - it's a brown wire with an inline connector so it's easy to ground the forward wire to check the gauge operation.
As for the range ona full tank, that has everythingto do with the engine configuraton, rear gears, and the driving style. It's a 20 gallon tank and gs mileage may range between single digits and upper teens.
An open circuit makes the gauge read beyone Full, towards the HOT light.The wire goes through a grommet in the trunk near the latch - it's a brown wire with an inline connector so it's easy to ground the forward wire to check the gauge operation.
455, auto and 3.55 rear end. Assume it’s 9-10mpg at best. So unchecked mileage and not paying attention. Oops.
