Lots accomplished!
Lots accomplished!
It had been raining up here last week because of the remnants of hurricane Jose so I could not get any work done on the car all week but it gave time for parts to arrive.
Both my rear windows were off the track. I was able to get one on last week by popping off the lower roller, getting the other rollers on track and popping the roller back on. Tried that with the other and broke the lower roller. The lower roller arrived and spent an hour tryining to get the window in and on track without popping off the new roller. No luck. While doing it the lower roller popped off. YEAH!! Got the two upper rollers on track, put the lower roller on the track without the window attached to it. Once there popped the roller back on and good to go. Both rear windows on track, fully aligned and seal well.
Installed door striker plates. Installed U shaped door jam seals. Not sure if installed properly. Does anyone know if the inner door panel should sit under it or over it?
Installed my front pillar post seals. That turned out well.
All I have left is my throttle cable. I was waiting on the ferrule that holds it at the redal. That came in so I should be all set.
Took her out to a wedding last night with the family. I must have a BIG *** GRIN on every time I drive it!
