1970 442 Restoration
Old June 27th, 2017, 04:45 PM
  #161
344879M363895
70-442-W30's Avatar
Hoping for the best for you Rick. I've been popping in every once in a while to get your updates. You need a great ending to this and I know you have everyone here pulling for you.
70-442-W30 is offline
Old June 27th, 2017, 05:35 PM
  #162
jensenracing77's Avatar
Is your machine guy located local to you?
jensenracing77 is online now
Old June 28th, 2017, 04:28 AM
  #163
Cincinnati Rick's Avatar
Well, we are definitely going to pull the motor. It could be as early as this weekend depending on the weather. I have some outdoor repairs I need to make on my house that I was going to work on but if it rains I'll be able to work on the car.
Cincinnati Rick is offline
Old June 28th, 2017, 04:33 AM
  #164
Thanks Bill.
Yep, he's local
Old June 28th, 2017, 04:43 AM
  #165
jharsh's Avatar
Rick, sorry to hear that. Hope it is a quick fix. You have put a lot of time and effort into this project, it looks great, and it should be time to enjoy the ride.
jharsh is offline
Old June 28th, 2017, 06:28 AM
  #166
Originally Posted by Cincinnati Rick
Yep, he's local
I know it don't help your situation now but if you do another engine and decide to go to another machine shop I would recommend Zimmerman Bros in Greensburg Indiana. He is expensive and has a waiting list but worth it in my opinion. I think it would be around an hour from Cincinnati. He is two hours from me but I will not go anywhere else now.
I sure hope it all goes well and back on the road soon.
Old June 28th, 2017, 10:53 AM
  #167
Thanks Eric. I'll keep everyone posted.
Old August 7th, 2017, 01:56 PM
  #168
Not good News
Pulled the motor out over the weekend and it doesn't look good. Lots of metal flakes where they don't belong. The crank and rod bearings are wiped out. Not sure at this point what happened. We are going to wash everything out, hone the cylinders a bit and replace what needs to be replaced. Thought about having the crank ground but my buddy is going to fix me up with a replacement. I'm keeping a positive attitude about everything because at this point, too much time and money has been spent to be bitter. I'm looking forward to getting the motor back in and cruising once again.
Old August 7th, 2017, 04:14 PM
  #169
tdhill01's Avatar
Sorry to hear the news Rick. I hope the remedy works for you and you get back on the road quick.
tdhill01 is offline
Old August 7th, 2017, 04:27 PM
  #170
65Delta's Avatar
Not good at all . Is the builder going to work with you to make it right or are you taking it elsewhere?
65Delta is offline
Old August 7th, 2017, 04:58 PM
  #171
Thanks Tom. I think we'll be good to go this time. Everyone involved is committed to getting me back on the road again.
The machine shop is going to touch up the cylinders and hot tank it. I don't think they are charging me anything for that. John is going to assemble it this time so I'm confident it will be done correctly. I'm paying for parts and he's taking care of the labor.
The consensus between him and the machine shop is that there was some sort of oiling issue. There was nothing obvious that we could see caused the failure. I'm listening if someone has some possible causes for this type of thing to happen.
Hoping to have it back on a run stand this weekend and back in the car the following weekend. Keeping my fingers crossed.
Old August 7th, 2017, 08:17 PM
  #172
Once Olds Always Olds
Troys Toy 70's Avatar
Rick, I am sorry. That just stinks, particularly knowing how strong it was running. I am glad you and John are getting it figured out.
Did you use a high volume oil pump?
Troys Toy 70 is offline
Old August 8th, 2017, 11:19 AM
  #173
tdhill01's Avatar
Hey Rick, misery likes company - I got a call today that someone backed up into my car at the body shop causing damage to the right front fender, right side headlight area and the hood. I'll need to have the fender replaced they said. Oh well, I knew I would run into problems but I didn't expect this.
tdhill01 is offline
Old August 8th, 2017, 11:27 AM
  #174
Are you kidding me? That really sucks. Was it a customer or an employee of the shop? You're not going to be out any money are you?
Old August 8th, 2017, 11:28 AM
  #175
No, I was told they are not used for stock/close to stock builds.
Old August 8th, 2017, 12:01 PM
  #176
I don't use them on my builds either but I don't building much more than stock either. I do shim the standard pump 1/4 inch though.
Old August 8th, 2017, 12:05 PM
  #177
tdhill01's Avatar
No, I shouldn't have any out of cost expense they said. It was a customer of theirs who was in a hurry when he backed up his car into mine. I posted for a 70 fender but I don't think I'll have the time to wait for one to materialize so I may have to place a 71-72 fender on her in the end.
tdhill01 is offline
Old August 8th, 2017, 12:18 PM
  #178
What does the shim do Eric?
I'll keep an eye out for one Tom. Good luck
Old August 8th, 2017, 12:50 PM
  #179
tdhill01's Avatar
Thanks Rick
tdhill01 is offline
Old August 8th, 2017, 12:59 PM
  #180
It will increase the pressure a little
Old August 8th, 2017, 02:02 PM
  #181
Ok, you two need to stop this, you guys are scaring me to death.
Tom, I cannot believe this, man am I sorry.
Old August 8th, 2017, 02:05 PM
  #182
Ok, I do have one but high volume is not high pressure. To get the pressure up, you have to call Melling and ask for a purple spring. Just thought I would ask.
Old August 8th, 2017, 02:37 PM
  #183
tdhill01's Avatar
Thanks Troy, I hope to get everything completed and have the car ready for Fall cruising.
tdhill01 is offline
Old August 8th, 2017, 02:49 PM
  #184
Tom, I sent you a pm.
Old August 23rd, 2017, 06:55 PM
  #185
Put the rebuilt motor back in over the weekend. Took a total of fifteen days to pull the motor, tear down, order parts, clean up the cylinders, install new parts , reassemble and put back in the car. Not bad for a couple of guys with full time jobs. Decided to install the W-455 intake I had instead of the iron intake this time. Took care of some misc. items this evening and took her out for a spin. It's hard to believe it's the same motor. Totally different feel(much happier) than before. Starts on first crank and idles like it never did before. My body guy/mechanic really stepped up and kicked *** to make sure my cruising down time this summer was kept to a minimum. I can't thank my friend John at Dusty Boots Restorations enough. Planning on putting some miles on tomorrow and Friday after work then taking a short road trip to the Cynthiana Ky Rod run on Saturday. I'll post some pics soon of the new power plant.
Old August 23rd, 2017, 07:23 PM
  #186
Funkwagon455's Avatar
Sometimes the small dissapointments ultimately render a greater long term satisfaction. I regret not being able to see this car in NM, but am grateful to have met you in person. Please share some pics when you can. I'm glad you've made this project behave the way you had ultimately expected.
Funkwagon455 is offline
Old August 23rd, 2017, 07:50 PM
  #187
tdhill01's Avatar
Great news Rick, enjoy taking her out and I hope you have many trouble free miles are ahead of you.
tdhill01 is offline
Del70
July 21st, 2020 11:42 AM
charlierogers
February 14th, 2014 02:30 PM
Jeff70442
June 12th, 2012 08:08 AM
Jeff70442
June 8th, 2012 04:38 AM
Jeff70442
April 11th, 2012 05:37 PM
Quick Reply: 1970 442 Restoration
