67 442 cowl tag help
#82
Another Cowl Tag question
Any input is greatly appreciated,
Thanks for all the info I have found.
This web sight is awsome.
Below is what i have looked up on my Cowl Tag.
Does any one know about the items on the bottom? Are the add on after or were they not listed in the Cowl tag area??
General Motors Corporation
06B Built Second Week of June D Not sure what the D is?
ST
67 1967
33817 Hard Top Holiday Coupe
LAN Lansing
29554 Production Number
TR Do I have this in car
970 Bucket Seats YES
P Passinger Seat Reclines YES
P-P Pewter-Pewter YES
E Soft Ray Tinted Glass YES
T Pontiac indicates Drivers Seat Is Power YES ?
2 Colum 2
E AC YES
G Center Console YES
T Rear Power Antenna YES
R Rear Speaker YES
3 Colum 3
B Rear Window Defoger YES
4 Colum 4
F Outside Remote Mirror YES
5 Colum 5
V 442 YES
Y Delux front seat belts YES
Are there any codes for these?
I also have these options.
Tilt wheel. YES
Cruise Control YES
Hi capacitor discharge ignition YES
Tic,Toc,TAC Gages YES
ST
67 1967
LAN Lansing
2 Colum 2
E AC YES
R Rear Speaker YES
3 Colum 3
4 Colum 4
5 Colum 5
V 442 YES
Tilt wheel. YES
Cruise Control YES
#83
There are two codes in the 1-5 COLUMN section that I've found without a decode - "3U" & "5H".
Tilt wheel - not coded in COLUMN 1-5 format
Cruise Control - ??
Hi capacitor discharge ignition - ??
Tic,Toc,TAC Gages - not coded in COLUMN 1-5 format
#86
I doubt someone would have added the UHV ignition and reworked it into the wiring harness??
Oh and does not coded in COLUMN 1-5 format mean those options were never added to any cowl tag??
Cruise Control - ??
Thanks and its inspiring to see others that finally got off there *** and got something finished. as you see my frame was off and blasted primed and is in black emeron. Now i just need to get my own garage and get something going again.
#87
Does that mean all these were added through the years?
Cruise Control - ??
Cruise Control - ??
For instances, tilt wheels, radios, ps, pb have nothing to do with the body, so there won't be an accessory code for them. Most of the body accessory codes are for particular body piercing required for the options.
So body accessory codes denote the presence or absence of some particular options only.
#89
The accessory codes on the Fisher Body data plate denote options that require something on or in the body or body related. It is not a code for the option itself, it is a code for a body modification.
#90
Actually the center rear seat belt uses the two existing inner bolts. It just means that Fisher must have installed the seat belts into the body shell. The front fenders were obviously painted separately and couldn't be installed until the body drop on the frame, but the fenders supplied by Fisher were different for a 66 442, or a hood for a 67 442, hence the 5V. Also, Fisher either supplied the emblems and trim, or made sure the body piercings were correct since different models [or 442 option] used different piercings. In 66, for example, the quarters on a Cutlass had the emblems in front of the rear wheels, but F85 and 442 had the same piercings near the rear. F85 and Cutlass trunk lids had different piercings. The 442 shared the Cutlass piercings.
#91
#92
Kurt - Is there a logical explanation for why the cowl tag makes a determination between STd and Deluxe in the seat belt code? The both use the same body piercing? i understand the reason for the code for the optional center rear seat belt because of the needed additional body piercing but why is there a code change simply because of the finish on the buckles?
I said that "most" of the codes were body piecing related. But not all. Think specifically about what has to done to the body before it leaves Fisher Body. Seat belts are included in the body assembly, and are not otherwise identified, so there is a code. The front clip is not part of the Fisher Body assembly , so there is no code for any of the hood and fender details.
#93
Yes, there is. But you have to think of the logic back then, not the logic now! Now, we're trying to determine what options came on the car. Back then, they were just trying to build cars, and what they did was to that end.
BTW - Joe D reminded me that the center belts were overlapped in the center seat belt holes so no additional piercing was necessary, but , indeed, the code was needed for the assembly men belt installers to add the center belt set.
Obviously they didnt make a Fisher body piercing for the W30 battery vent tube or it would have had a code. As noted before the battery cables went through holes punched in the oval trunk floor plug/covers so good reason to not have a code. The battery cable hold-down clamp holes, the cable holes in the plugs and the vent hole in the floor were all written on the same print with exact hole placement locations detailed on the drawing!! Just not sure if same drawings were used on factory installations at assembly plant or were just the drawings that were provided with the "track Pak" over-the-counter OAI packages.
"Today there would be and "APP" for that!! LOL - Have a great day!!
#94
Interesting, Kurt. I assumed that the fenders and hood were painted by Fisher at the same time as the main body shell, and were supplied to the assembly plant. Are you saying that you have evidence to the contrary?
#95
#97
I believe the holes are indeed different.
#99
#100
Hello guys, can someone please help me decode the rest of this cowl tag:
058 = ??
ST 67-33817 LAN24534 = 1967 HT (Holiday) coupe build in Lansing
TR 980-C = Black interior, Bench seat also in black A-A = Black on Black paint
ES 2ER =??
5VY = 442 / deluxe seatbelts
058 = ??
ES 2ER =??
#101
ST67 = 1967 model year
33817 = Oldsmobile Division (3) Cutlass Supreme (38) Holiday Coupe (17)
LAN = Lansing assembly plant
24534 = Fisher Body sequence number
TR 980 C = black vinyl bench seat interior
A-A = Black upper and lower body colors
Acc Codes
Group 1
E = Tinted Glass
S = Power Trunk Release
Group 2
E = Firewall piercing for A/C
R = Rear Speaker
Group 5
V = 442 option
Y = Deluxe front and rear seat belts
#103
L77F85
January 19th, 2015 11:47 AM
