Will it fit? S-10 Wheels and Tires
Wondering if these wheels will fit on the 442 for transport? I plan on going to PA next week to get the car. The price is right for these tires and way better than what's currently on there. The car may be sitting in my garage for a while before it is up and running again and then at that point I'll buy the new tires for the original wheels.
Tried checking some used tire places for GR 70-14 substitutes, for the E-T rims on the car currently, but no luck in finding a 14 inch that wide in a used tire. Maybe 15 years ago...
They are 225/75/15 on the needed 5x4.75 pattern, but I'm not sure if the clearance will be there.
Thanks!
Not that I don't trust you, but I could use another member's confirmation on this. The last thing I want to do is make the trip and find out the things wont fit.
Anyone else positive on these? They wont be driven on. Just for transport and garage use.
Called the guy before and it turns out it is a motorcycle business. Maybe I won't get a call back till Monday.
Hi, hope I'm not too late! I tried to put an S-10 Xtreme wheel on the rear of my '69 442 (axle is out of a '70) and the center hole wouldn't clear the center flange on the axle end. These were 16" and a different style from what you have pictured, but might be worth checking. I didn't try it on the front.
Seemed odd to me but I couldn't get it to fit. It's possible the flange stuck out further on the 442 than on the S-10 and the hole in the center of the wheel stepped down a bit so it wouldn't go all the way on.
More likely there was corrosion on either the wheel, the axle or both that was preventing the wheel from seating.
navvet
Suspension & Handling
March 30th, 2015 11:05 AM
oldsguybry
Wheels and Tires
19
February 16th, 2013 09:14 PM
