Click Here
Rim tire fitment question
Old May 4th, 2016, 05:06 PM
Big Dawg's Avatar
Hey guys,
I am looking at purchasing a set of TSW rims that were on a 72 Nova for my 69 442.
18x9.5 with 20mm offset 275/35/18 on all for corners
just want some input if whether or not the following wheel and tire combo will work on my car.
Thank you
It is setup with stock suspension right now.
Big Dawg is offline
Old May 4th, 2016, 06:48 PM
svnt442's Avatar
I have a feeling that those hit that nova all over the place, at least in the front.
+20mm offset is what the 5.0 mustangs used in the mid 80's and early 90's on a 7" wide wheel. Add another 2.5" to that and you end up with a pretty massive lip and I'd bet money that they won't clear the front fenders at the very least when turning. They might even hit the frame or the control arms on the backside when turning.
I would do a test fit before committing to purchasing these just to be on the safe side.
svnt442 is offline
Old May 5th, 2016, 07:26 AM
275/35-18s are a whole 25.5" in diameter. They will look lost in the A-body wheel wells, which really want tires closer to 26.5" or 27" in diameter. 20mm offset is about 0.8" - is that positive (inboard) or negative (outboard) offset? Inboard means they rub on the frame or inner fender, outboard means they rub on the wheel opening lip.
joe_padavano is online now
Old May 7th, 2016, 02:54 PM
Big Dawg's Avatar
Thanks for the input guys.....i decided against them.
Big Dawg is offline
Brians64f85
Wheels and Tires
November 15th, 2012 11:53 AM
skryla
Wheels and Tires
June 2nd, 2012 10:45 PM
Rolds72
Wheels and Tires
March 20th, 2012 12:39 PM
steve terry
Wheels and Tires
January 29th, 2010 12:15 PM
audiodox
February 13th, 2009 01:22 PM
Quick Reply: Rim tire fitment question
