GM A body tilt column in '70 VC?
Does the vista cruiser have a specific column in it? I wanted to upgrade to tilt, can I buy a tilting column for any A body? For one designed for a cutlass?
Assuming your car is an automatic on the column, there are 4 different columns available in the 1969-'72 A body for cars with automatic trans. They are column shift, column shift with tilt, floor shift, & floor shift with tilt. As long as it is a column shift with tilt from a '69-'72 A body(Cutlass, Lemans, Skylark, Malibu), it should be a direct bolt in for your Vista. You might want or not want to change the shifter lever, turn signal lever & tilt lever to Oldsmobile specific versions if you care about being "correct".
starfire
December 9th, 2021 08:21 PM
Rocketbrian
October 2nd, 2013 10:18 AM
Bitburger
December 30th, 2012 04:49 PM
ELECMAN
January 22nd, 2012 01:49 PM
ros6872
February 24th, 2010 05:50 PM
