1955 Oldsmobile Power Steering
Old March 15th, 2016, 02:04 PM
Gene Fettig's Avatar
Hi I have a 1955 super 88 Olds. completely restored I have spotted a complete power steering unit but the gentlmen is not sure if wants to sell it. My question is how much of a problem is it to change it over i have looked at it, and not quite sure how the steering column comes out would appreciate some comments and some help with this. Thank you. Geno.
Gene Fettig is offline
Old March 15th, 2016, 02:14 PM
Welcome to the site, I moved your post to the Vintage section. They are a great bunch and should be able to answer any question you have. Post an intro in the Newbie section with some pics for us.
oldcutlass is online now
Old March 15th, 2016, 03:24 PM
lonestarjarhead's Avatar
55 power steering
The steering column has to come out with the steering gearbox.
lonestarjarhead is offline
Old March 15th, 2016, 03:46 PM
Proud Viet Nam Veteran
redoldsman's Avatar
The shaft comes out of the box and goes all the way up to the steering wheel.
redoldsman is online now
Old March 15th, 2016, 04:14 PM
Rocketowner's Avatar
Geno, welcomed to Classic Olds.There is a step by step article on E-how on "Hot to remove a Chevrolet Manual Steering Column." It should be basically the same process on the Olds.I changed a '54 Chevrolet I had to power steering ,and remember it having a different Pittman arm. I would be sure to get the Pittman arm with the power steering gearbox.
Hope this helps, Larry
Rocketowner is offline
Old March 15th, 2016, 06:47 PM
redoldsman's Avatar
I added power steering and power brakes to my 54. It really makes the car a lot more enjoyable to drive. My suggestion if the condition of it is unknown is to ship it to Chip at Power Steering Services, Inc. in Springfield, MO and have him rebuild it. He is a great guy and does great work. Lots of folks on here have used him.
Old March 21st, 2016, 08:16 PM
Gene Fettig
Thank you gentlemen your remarks were really helpful I have a pretty good understanding what has to be done, the only problem is I can't find a complete ps unit will have to keep on looking. Thanks for all of the advice. Geno
Old March 21st, 2016, 08:54 PM
redoldsman's Avatar
A complete unit is hard to come by. You need the steering sector, the pump and bracket and the double pulleys. The pitman arm may be different but I am not sure.
Old March 25th, 2016, 12:12 PM
I found a complete ps unit, my question this unit is out of 1954 98 will it fit into my 1955 88 without any modification. would you email me. Thanks. verngeno@bis.midco.net
Old January 12th, 2017, 03:17 PM
Gentlemen I finally got back on line I got my PS installed in my 55 olds. Sure is nice. Got kinda expensive till I got it over hauled. everything from a 53 thru 55 fit all fit mine came from a 54 everything was interchangeable. Thank guys for all of your advice. Geno.
Old January 12th, 2017, 08:11 PM
redoldsman's Avatar
Congrats Geno. It sure does make the car drive better. The cost is considerably more than it was from the factory in 1955.
Old February 15th, 2017, 07:56 AM
Frank Allen's Avatar
54 and 55 are exactly the same, remove floor plate, disconnect pitman arm, bold on frame and wireing and pull column out gear box and all, the power column will bolt right in, install double pulley on crank shaft and water pump , bolt pump to engine hook up lines and go for it. I pulled my out of a junk yard along with the power brake and put them in my car as is, had to rebuild the power brake, steering was installed as is and has worked perfect ever since, installed 17 yrs ago. hope this helps.
Frank Allen is offline
Old February 22nd, 2017, 01:57 PM
holidaysedan's Avatar
I'm doing the same on a '58 Super 88, so is the outer shell of the steering column the same, in other words is it just the internal shaft of the column that needs changed, along with all the other stuff mentioned above?
holidaysedan is offline
Old February 22nd, 2017, 02:22 PM
Holidaysedan, power steering on olds changed in 1956, will not fit older models, they added a rag joint, also the gear box will not fit older models, after 56 I don't know what changes are made. try to find a 58 so you can be certain things will fit.
Frank Allen
Old February 22nd, 2017, 03:39 PM
Have the parts book, most of the '57 PS stuff is the same as '58 w/ minor exceptions, my friend has a '57 parts car and I already got all the PS parts. What I can't determine is if the outer shell of the steering column from my car is usable, it's in much better shape than the one off the parts car, but I have that one too, just in case.
Old March 27th, 2017, 11:08 PM
Williamaronson's Avatar
I would love a spare power steering column and box so as to get them rebuilt but still permit me to use the car. Anyone with any knowledge of anyone selling any units?
Williamaronson is offline
Old March 12th, 2021, 10:47 AM
Allen Faltus's Avatar
It is not difficult to remove the column and steering gear. It is all one assembly. Once you remove the steering wheel, directional signal lever and outer upper jacket, the whole assy. is removed from the bottom. It is heavy and long so best to have it on a lift. .
Allen Faltus is offline
rv21350
July 17th, 2023 07:43 AM
rket56
February 12th, 2021 08:09 AM
69Chrgr
October 16th, 2019 12:40 PM
MerryOlds
May 6th, 2014 08:29 PM
rocket78
July 11th, 2012 08:00 AM
Quick Reply: 1955 Oldsmobile Power Steering
