Rear Differential Oil
Hello. This is probably a stupid question but I need to ask!
I am going to change the oil in my rear differential.
What I am wondering is can the car be backed up on ramps or does it need to be level?
I am going to remove the cover, clean it and install a new gasket.
Also would it be better to use synthetic or regular Differential 80 oil?
Just make sure the transmission is in neutral or else the differential action will cause the wheels to spin in opposite directions due to the driveshaft being locked.
