70 Cutlass - TH350 Pan gasket R&R Cross member removed?
70 Cutlass - TH350 Pan gasket R&R Do you need to remove Cross member?
Do you need to loosen/shift the cross member over to remove the pan. I think I can get the two bolts out along the front, just want to be sure once I remove all bolts, that the pan can drop/clear the filter with the cross member in place...
thanks
thanks
The pan on my 70 and 71 would come off without loosening the cross member, but it was a bit tight. I typically first let the front of the pan drop (the rear lip gets trapped by the crossmember when it tips) and dump fluid, then work the rear of the pan out.
ddd777
May 15th, 2016 05:55 PM
WTony
April 22nd, 2015 11:27 AM
harry k
November 21st, 2012 08:54 AM
dallasite21
June 20th, 2010 05:37 AM
