| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
Wanted for 66 Toronado
I just had a u-joint cap break and the axle come loose. I need, at least, a u-joint and caps, probably the flange as well. This is the inboard u-joint.
Thanks e-mail mantle@ruralnetwork.net |
| Sponsored Links |
#2 (permalink) |
Oldsdruid
You'll probably come out as cheap buying a remanufactured axle assembly. You might get a RH that doesn't have the rubber torsional damper, but fit & function are the same. I didn't notice any differences in my 69 after replacing the RH axle, and I tend to drive the car hard.
__________________
I know absolutely nothing about Oldsmobiles. Just ask the owner of Oldspower.com |
#3 (permalink) |
Junior Member
This unit has a large flange secured with six 12point bolts. Two of the u-joint caps bolt into the flange and are triangular in shape and the bolts come in from the back of the flange. This afternoon I found a u-joint but after looking at the flange I find I'll need to replace it.
The flange is approx. 6 1/16th" in diameter and 5/8th" thick. It has 6 holes around the outer edge, and has a machined 5" locating flat on the back side. The center has a machined opening approx. 2.25" X 3.75" with 2 holes on each long side for the u-joint caps. This is definately not a CV system. The u-joint is a spicer 5-356X and shows dicontinued in the computors. By chance, someone remembered a small driveline shop that the owner used to do Toronados and Eldos and I found an 80+ year man who who went right to the back and pulled it out. Say's "that's it, got no more!" The box is real OLD. |
#4 (permalink) |
Member
I`VE THE WHOLE FRONT WHEEL DRIVE SET UP FOR THE 66 WOULD THAT WORK
#5 (permalink) |
Junior Member
I don't need the whole set-up, or rather, I don't need to pay shipping on stuff I don't need.
When you are near the Toronado next time, look at the inboard end of the half shafts. You'll see two 6" diameter flanges joined around the outside by six 12point bolts, head diameter of 7/16ths. There should be a u-joint connected to the outside flange. It is that flange, aproximately 6"X 5/8th" that I need, and I could use the u-joint as well. Both sides even? I have through some sort of heavenly intervention found 1 of the u-joints new in box, and I have a machinest that assures me he can make the flange, but it'll be some time before he's caught up and can get to it. If the parts you have include what I need i'm interested. Mike |
#6 (permalink) |
Senior Member
Transmission parts
I've got a 1966 and a 1977 parts cars. I'd rather not pull parts off the early transmission as it's a switch pitch. But if that's the one you need send me a pm with an offer including shipping from Medford Oregon and I'll consider it. John
__________________
1964 Cutlass Factory 4spd 1965 442 4spd 1967 442 Auto 1967 Cutlass Convertible 1968 442 Auto 1969 442 W30 Auto 1970 442 4spd 1971 Cutlass Flat Top Wagon 1973 Che*vy 3/4 Ton 454/TH400 Tow Vehicle Only the tow vehicle is finished! |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wanted 66-70 Toronado 15x6 rims | cig1ar | Parts Wanted | 4 | 08-27-2008 05:20 AM |
| HELP: Wanted 1984 Oldsmobile Cutlass Calais 2 door, T-top parts wanted. Interior..rea | Patric1984Olds | Parts Wanted | 3 | 03-22-2008 04:36 PM |
| Center caps wanted for 1987-'89 Toronado Alloys | thebluesking | Toronado | 0 | 11-14-2007 04:24 PM |
| '71 Toronado | 67htc | Cars For Sale | 0 | 07-01-2007 06:37 PM |
| Toronado intakes oil pans and motor mounting harware wanted | B.O.P. Connection | Parts Wanted | 0 | 10-29-2004 11:34 PM |
