Toronado Headlight Action ???
Old May 6th, 2016, 07:46 PM
Senior Moment Member
z11375ss's Avatar
So, I got the vacuum issue worked out with my headlights. They operate but don't want to close all the way immediately. If I let the car sit they do close after a while. Is there a secret to getting these things to operate more freely? I haven't climbed under the front bumper to see if I can grease them or something. But I'm just putting this out there to see if there are some Toro guys here who know more about this than I. That would be almost everyone. Thanks in advance.
z11375ss is offline
Old May 6th, 2016, 09:44 PM
z11375ss's Avatar
Maybe this is what I need?
https://classicoldsmobile.com/forums...-problems.html
z11375ss is offline
Old May 16th, 2016, 11:26 AM
TahoeRob's Avatar
What year is your car? Here's a write-up on working on a '67. 68 and 69 are similar, but each are a bit different, I believe.
http://www.toronado.org/FAQ/GenI/67can.htm
TahoeRob is offline
Old May 20th, 2016, 07:23 PM
z11375ss's Avatar
Thanks. I'm going to hunt this stuff down and get them working right. It seems like they aren't bleeding off correctly. As if the line for the bleed off is clogged.
z11375ss is offline
Old May 25th, 2016, 01:17 PM
TahoeRob's Avatar
Do the latches release when you push in the lever? If so, it's likely just an issue with the diaphram, which is likely just sticky. Spraying it down with silicone might help.
TahoeRob is offline
Old May 25th, 2016, 01:18 PM
TahoeRob's Avatar
Also, if you haven't lubricated all of those moving parts, I would recommend that. Spraying all of the hinges and latches down with TriFlow helped the action on mine quite a bit.
TahoeRob is offline
Old May 30th, 2016, 12:13 PM
z11375ss's Avatar
I have lubricated the moving parts but didn't know about lubricating the diaphragm. Where is this located? On the fenderwell? I'm not near the car. That's why I'm asking. This I will try next! Thanks.
z11375ss is offline
jensenracing77
May 12th, 2012 05:00 PM
doc93
May 21st, 2010 12:51 PM
gearheads78
October 14th, 2009 09:56 AM
venividivici53
August 11th, 2009 05:19 AM
joe_padavano
February 10th, 2009 05:41 PM
Quick Reply: Toronado Headlight Action ???
