'66 Toro heat riser question
Old February 9th, 2016, 06:17 PM
Pete Kaczmarski's Avatar
My car has 47k original miles and last year it developed a slight by annoying exhaust leak. It is leaking where the shaft of the heat riser valve comes thru the exhaust manifold. Is there a sleeve that is cut to go over the shaft and into the manifold or any other ideas......Thanks
P.S. the heat riser still works
Pete Kaczmarski is offline
Old February 9th, 2016, 07:19 PM
timb's Avatar
i hope so mine will need the same thing .it's leaking at the seal so bad i can't tell if the shaft is leaking.
timb is offline
dingusboy
March 8th, 2014 07:09 AM
1977 Delta 88 Flint
December 24th, 2012 11:25 PM
Ian U
July 7th, 2010 01:39 PM
StickW31
January 21st, 2010 08:12 AM
bjtstarfire
November 13th, 2008 02:04 PM
Quick Reply: '66 Toro heat riser question
