ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Technical & Reference > Tech Editor's Desk
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old October 21st, 2009, 10:14 AM   #1 (permalink)
dale.rainier
72 Old Cutluss ~ Problem
Hey, I am having a problem where when I turn the key the starter doesnt turn really nothing happens at all (did check the fuse), but I am able to jump the starter and the car runs fine. Battery and Alt are good. Any ideas what could be the problem.
dale.rainier is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old October 21st, 2009, 10:33 AM   #2 (permalink)
70 cutlass s
Check the wire going to starter to see if its hot when the key at the start pos. Might want to check the linkage go from the trans to the steering column make sure its adjust right or the neutral safety switch would keep it from starting. Also might to check the wire going from the starter to the coil.
70 cutlass s is offline   Reply With Quote
Old October 21st, 2009, 03:25 PM   #3 (permalink)
72 cutlass455
72 cutlass455's Avatar
Could be a bad starter solenoid .
72 cutlass455 is offline   Reply With Quote
Old October 21st, 2009, 03:27 PM   #4 (permalink)
lovemy69olds
get the old test light out.
lovemy69olds is offline   Reply With Quote
Old October 21st, 2009, 04:33 PM   #5 (permalink)
bcracing
bcracing's Avatar
If you don't have power at the starter. May be the netural safty switch itself. Try starting it in netrual. or pulling up on the shifter.
bcracing is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Idling problem ND71 General Discussion 1 September 15th, 2009 07:27 PM
Trans Problem... help! 455Gbody Transmission 6 August 5th, 2009 12:51 PM
AC problem LRC Intrigue 0 July 13th, 2008 07:54 PM
Transmission problem!!! Please help veltboy618 Cutlass 1 July 9th, 2008 09:20 AM
1973 Olds Cutluss Custom TheConcierge Cars For Sale 0 November 1st, 2007 02:07 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
