Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Over heating problem / water pump question
Old May 12th, 2016, 10:25 AM
Walterdurbin's Avatar
65-442. 400ci stock a/c car ...was over heating when at red light a/c off .. Found that I had 7# rad cap ..changed to 16# and went with 180* therm. Now I am getting leak behind water pump which I did not have before ... When looking Thur rad cap inlet you can see water moving rapidly
Question is water pump still good and gasket went bad or pump is out ... Can't tell if it is coming from small hole bottom side of water pump or not but you can see water coming from under water pump. Any help here!!, thanks
Walterdurbin is offline
Old May 12th, 2016, 11:48 AM
It could be leaking not only from the weep hole on the bottom, but also radiator hose, bypass hose, and heater hose. Does the water pump shaft move when you wiggle the fan forward and rearward?
oldcutlass is online now
Old May 12th, 2016, 11:59 AM
It does not go forward and backward but does wiggle fro side to side
Old May 12th, 2016, 12:06 PM
I'd probably go with bad water pump.
Old May 12th, 2016, 12:25 PM
I think your right ... When it over heated 40 miles from my house I filled with 50/50 antifreeze and drove home .. Temp never got above 205 ... When pulling into garage it started spilling out hole in pump ... Let it cool down .. Filled up with just water and it dripped out of same hole ... Going to order one now Thanks
Old May 12th, 2016, 03:32 PM
Octania's Avatar
Take your wp to the store, or provide its casting ID and we can tell you its measurements.
There are three lengths, two different inlet nipple sizes, and some other less troublesome variations to make sure you get right.
Do not turn in your old WP for a core if it has OEM casting ID's unless it is the ubiquitous #4 casting.
Octania is offline
Tedd Thompson
August 8th, 2015 01:42 PM
ryanhooton10
August 31st, 2013 07:25 PM
Joey Lights
October 14th, 2011 11:40 AM
1971 442 convert
August 17th, 2011 07:54 PM
bkeese
March 28th, 2011 10:02 AM
Quick Reply: Over heating problem / water pump question
