ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old December 16th, 2008, 05:46 AM   #1 (permalink)
Bunser
Air fuel problems
I have a 70 W31 engine with the original quadrajet carb.When dyno tested the A/F readings were ranging from 7 to 9. Just a bit rich.Any suggestions (except from Norm) would be appreciated.Thanks.
__________________
70 W31 in progress (Currently trying to put the innards back together after it was held hostage by a scumbag body shop owner.)
Bunser is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old December 16th, 2008, 07:35 AM   #2 (permalink)
cutlassefi
Air/Fuel
Gotta check a bunch of stuff, the bowl plugs, they normally leak, fuel pressure, yes the primaries do have metering rods, are they sticking etc. Needle and seat, good condition, set right? If possible try another carb on it. Or you maybe have to send it out to a more competent rebuilder. Good luck!
cutlassefi is offline   Reply With Quote
Old December 16th, 2008, 08:37 AM   #3 (permalink)
rocketraider
Oldsdruid
W31 shouldn't have primary metering rods, unless everything the factory put out about them is a lie...
Are these A/F readings at WOT or thruout pull range?
__________________
I know absolutely nothing about Oldsmobiles.
Just ask the owner of Oldspower.com
rocketraider is offline   Reply With Quote
Old December 16th, 2008, 11:18 AM   #4 (permalink)
cutlassefi
Air/Fuel
Sorry guys, every Quadrajet I've ever seen had primary metering rods. My mistake.
Old December 18th, 2008, 05:12 AM   #5 (permalink)
Bunser
It probably doesn't interest too many,but, on runs three days apart, the following results were obtained.On the first day the readings ranged from 11.4 to 14.0. Three days later (same secondary rods and same hanger) it ranged 7.8 to 9.8 with rpm range from 3000 t0 5500.
His explanation was different atmospheric pressure or air density or maybe tooth fairy dust. I'have to believe that his test instrumentation needs calibrating/overhauling! Any comments welcome.
__________________
Old December 18th, 2008, 09:47 AM   #6 (permalink)
cutlassefi
Air/Fuel
I agree. At around 8.0 to 1 air/fuel I'm pretty sure it would have been belching black smoke. May want to try someone else, at the very least different equipment.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ram Air Hood...vendor problems! #1CutlassSupreme Small Blocks 11 February 8th, 2009 12:34 PM
1968 442 air forced air cleaner Viper Parts Wanted 0 August 13th, 2008 11:58 AM
fuel pump problems dandl1862 Cutlass 3 August 14th, 2006 04:29 PM
'86 307 vacuum & air hose problems jrbarrie83 Small Blocks 4 July 9th, 2006 10:26 AM
to much air in my fuel line diablo76delta88 Small Blocks 2 February 27th, 2004 09:22 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
