ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old December 8th, 2008, 08:15 PM   #1 (permalink)
gumbyssfakee
Intake swap
Hi I have a 71 cutlass with a 350 and a 2bbl. I'm looking for a little more kick when i step on the pedal and want to get a 4bbl with the performer rpm manifold. If i was to make this switch what problems should i expect to encounter such as hood clearance or parts that just don't fit anymore? Or is this a straight forward pull the old one off and drop the new one on deal?
summit rochester
http://store.summitracing.com/partde...5&autoview=sku
intake
http://store.summitracing.com/partde...1&autoview=sku
gumbyssfakee is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old December 9th, 2008, 05:37 AM   #2 (permalink)
Oldsguy
Hot Rodder at heart Administrator
Oldsguy's Avatar
Should fit under the hood without clearance issues. You will need a throttle cable and spring and an air cleaner for the 4bbl and probably some different vacuum accessories.
__________________
Dan
'77 Cutlass Supreme
'46 2 door
"The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB.
Oldsguy is offline   Reply With Quote
Old December 9th, 2008, 06:27 AM   #3 (permalink)
74 Omega
74 Omega's Avatar
I think you will also have to convert to a manual choke.
__________________
Dave
1974 Olds Omega S (Who Cares about MPG)
1999 HD Road King Classic (50 MPG)
2001 Monte Carlo SS (25 MPG)
2004 Silverado 2500HD 4x4 Crew Cab (10.5 MPG)
2001 Oldsmobile Intrigue
www.sdcookman.com
74 Omega is offline   Reply With Quote
Old December 9th, 2008, 07:10 AM   #4 (permalink)
joe_padavano
Super Moderator
Quote:
Why? Just use an electric choke. You can get an aftermarket version from Borg Warner that has a temp sensor that is held under one of the intake manifold bolts.
As for the specific intake selection, is the motor otherwise stock? What do you plan to do with it? If you mainly are using the car for low RPM street driving with a stock exhaust, the Performer (as opposed to the RPM) might be a better choice for torque and economy.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old December 9th, 2008, 07:50 PM   #5 (permalink)
gumbyssfakee
i plan on putting some work in the motor if i can ever get the money together. my goal is over 400 hp. right now its stock with a flowmaster 2.5inch exhaust and flowtech headers. i figure if i need to replace things i might as well take a step up instead of buying stuff i dont plan on keeping. the current 2bbl has to go because it needs a rebuild and backfires when i accelerate. as for the intake the stock is fine but i believe the performer rpm is lighter and does add something over the stock.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
intake swap cutlassinvt Small Blocks 23 July 7th, 2008 11:54 AM
v6 to v8 swap Cutlass83 General Discussion 6 April 13th, 2008 07:50 AM
w-350 Intake or Edelbrock Intake 71cuttyS Small Blocks 5 October 31st, 2007 05:58 PM
260 Intake swap? xbody Small Blocks 8 July 20th, 2007 08:10 PM
swap wagonman Other 10 April 23rd, 2007 06:46 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
