| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
I found my problem
Ok I found my problem(s). I have a 72 350 in my 84 Custom Cruiser. I bought it off Ebay for $400. The guy I got it from said he thinks it has a cam. I know it has Competetion CAms roller tipped rockers. and an Edelbrock intake. The car now has true duals. The carb is q Q-jet. I am also running a Holley electric fuel pump not that it should matter. So now to my problems. Turns out I do have a vacuum leak. I tested it the same way as before but today it worked. I used carb spray and today the engine sped up when I sprayed the passenger side mid way back. It's leaking at the intake gasket. And around the heat riser, even though I used a gasket there. Now I have questions. Is it ok to drive like this? Right now it runs fine at regular throttle. The secondaries will not kick in. If I jump on it then the engine just falls on it's face. I would bet this is a direct result of the vacuum leak, right? I'd like to take it on a 4 hour trip but i'm not sure as the A/F guage is showing way lean at partial throttle. I checked a plug but only before finding the leak. I checked the #1 plug, not one by the leak. So again should I drive it like this? If so is it ok to take it on the highway for four hours? I know I have to put new intake gaskets on it. Just wondering how soon It has to be. Also is there anything special I should know about putting new intake gaskets on? Also I have a lifter tick. Can I put new lifters on a cam that's already there? Thanx mates.
__________________
1979 Olds Cutlass Cruiser ChopTop delivery 1984 IMSA Super Duty powered Fiero 1984 Olds Rocket 88 Custom(BattleCruiser)Cruiser 1996 Subaru wagon 2000 Totalled Dodge Caravan. |
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
ROCKETeer
i wouldnt drive it like that. and i believe its not just intake gaskets like a SBC, mine has a metal valley pan for the intake gasket, and you have to silicone the shit out of it...
__________________
CPL 3531 U.S.M.C Motor T 03'-07' "motivator and sloperator" '68-'70 olds 350 rocket/ th350 trans/ 88 4 door fleetwood brougham ( swap complete ) ![]() Connecticut, crappy weather, crappy roads. " I like my coffee strong enough to float a pistol. " |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| just found this site | oldsmbl | Parts For Sale | 7 | September 5th, 2008 09:31 AM |
| Found a 72 toro | J-(Chicago) | Toronado | 2 | August 30th, 2008 08:19 AM |
| Finally found one | dar83501 | Cutlass | 23 | February 11th, 2008 08:33 PM |
| Found a 1964 F-85 V8 | Harlow383 | Cutlass | 4 | July 11th, 2007 10:58 PM |
| found a 68 442 | ernest442 | 442 | 3 | August 12th, 2006 01:07 PM |
