Collasped Lifter??
Old March 6th, 2017, 04:00 PM
  #41
How did you fix the bent driveshaft the first time?
oldcutlass is online now
Old March 6th, 2017, 04:01 PM
  #42
RandyS's Avatar
Originally Posted by AtomicT
Hmmm, Ok then. I'll start with the easy stuff, bent wheel and balancing. Then move onto the driveshaft and axle. They can't be that hard to swap out? (I'm laughing as I write this......)
Actually, most axles and driveshafts are really easy to remove/install.
RandyS is offline
Old March 6th, 2017, 04:52 PM
  #43
With the car sitting for so long it could be flat spot on a tire.
Fun71 is offline
Old March 7th, 2017, 07:48 AM
  #44
AtomicT's Avatar
I went to Universal Joint Services in Rutherford NJ. I was told he was the only guy around. I watched him do it on the spindle thingy. It seemed pretty legit. Took like 20 minutes and cost me $35 if i remember correctly
AtomicT is offline
Old March 7th, 2017, 07:49 AM
  #45
AtomicT's Avatar
That may be the case, I am holding out hope for the front ones since I just put them on, but I'm afraid the back ones may be done in by flat spots.
Do they ever come out?
AtomicT is offline
Old March 7th, 2017, 07:51 AM
  #46
AtomicT's Avatar
Really? Never done it before, never had to. Are there any olds specific tutorials anywhere I could reference?
AtomicT is offline
Old March 7th, 2017, 08:28 AM
  #47
Then I would probably rule out the drive shaft.
Old March 7th, 2017, 11:41 AM
  #48
I don't trust any of these people. You never know.
As far as the tires, "flat spots" were a much more significant problem on the old bias ply tires. Newer radials seldom do that, though it is not impossible.
The old remedy was always to go for a very long, very fast drive, which would heat them up and smooth them out, but it's not reliable.
Having them balanced will probably not find a flat spot (though newer balancing machines which can put a car's weight on a roller attached to the machine and roll the tire may find it), but it should isolate problems with balance and bent rims.
MDchanic is offline
Old March 7th, 2017, 01:18 PM
  #49
Out of Line, Everytime😉
olds 307 and 403's Avatar
Were new U joints done on the drive shaft? Welcome to drving old cars.
olds 307 and 403 is offline
Old March 7th, 2017, 01:24 PM
  #50
AtomicT's Avatar
Hahaha! Yes driving old cars for regular transportation, like a constant itch you can't get but are ok living with! As for the u-jonts, no. Would they be a cause for this vibration. Are they hard to change?
AtomicT is offline
Old June 12th, 2017, 02:35 PM
  #51
AtomicT's Avatar
Just to finally close out the last part of this for all the people who helped me - it was the tires. They had gone bad from not being used enough are were so very warped. I couldn't see it in my garage, but the guys at the tire shop rolled it down the shop and it wobbled so bad it looked like it would fall over. So new tires, vibe went away.
Thanks for all the input. Now see my new thread where the new problem is. Ugg
AtomicT is offline
Old June 12th, 2017, 06:22 PM
  #52
I assume its running well now also.
Old June 12th, 2017, 08:37 PM
  #53
steverw's Avatar
I would have a new drive shaft made or find a known good used one. I dont trust having a bent shaft straightened, plus it will probably wear out the bushing in the tail housing of the transmission. This can also cause a straight shaft to wobble if not replaced.
Good luck.
steverw is offline
Railguy
April 9th, 2012 07:29 AM
ah64pilot
April 9th, 2012 06:41 AM
mp71conv
December 17th, 2008 11:03 PM
CutlassSalon
August 24th, 2008 06:33 PM
#1CutlassSupreme
May 13th, 2008 10:40 AM
Quick Reply: Collasped Lifter??
