ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old June 15th, 2008, 01:42 PM   #1 (permalink)
Chumley
'72 air cleaner
I have seen several '72 air cleaners on Ebay. The round part that fits over the carb is a perfect circle. The '73 air cleaner that is on ny '72 Q-jet has a notch in the front that fits over corresponding part on the carb. I guess the ones on Ebay are for 2 barrel carbs? I know they would not fit without that notch. Chumley
Chumley is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old June 15th, 2008, 02:48 PM   #2 (permalink)
joe_padavano
Super Moderator
Quote:
No, the 2GC 2bbl carbs have a much smaller diameter air horn than the Qjet. The air cleaners with the notch are designed to ensure the snorkel lines up correctly with the heat stove and the fresh air inlet. Also, some of these air cleaner housings have notches for the HEI and need to be properly clocked for that.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old June 18th, 2008, 07:18 PM   #3 (permalink)
Chumley
So the ones without the notch are for engines that did not have the thermostatic controlled air cleaners? My '70 had one, and I thought they were pretty much standard equipment since then.(on taking a second look at mine with the notch, I guess the one without a notch would fit, although it would not be "locked" into place.) Would there really be that much movement if the lid screw were tight enough?
Chumley
Old June 18th, 2008, 07:56 PM   #4 (permalink)
joe_padavano
Super Moderator
So the ones without the notch are for engines that did not have the thermostatic controlled air cleaners? ...
No. What I was trying to say is that as the 70s went on and there was more "stuff" that connected to the air cleaner, it was more important for the air cleaner to be positively located in a specific orientation. The incorporation of HEI distributors in 1973 was probably the event that triggered the notch for clocking, since many of these air cleaners needed a clearance "dent" on the underside to clear the larger distributor cap.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1968 Air Cleaner dan1s Parts Wanted 1 March 13th, 2008 11:38 AM
air cleaner questions ??? Good_Music_n_Cars Small Blocks 4 October 28th, 2007 07:53 AM
air cleaner color Want-A-Vert Cutlass 0 April 2nd, 2007 09:15 AM
67 442 Air Cleaner wj67442 Parts Wanted 0 February 15th, 2007 04:54 AM
Air Cleaner Color Want-A-Vert Small Blocks 7 January 22nd, 2007 10:44 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
