| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Alero Chapter Secretary
Good oil pressure
1968 350?
I replaced the PCV valve and runs at 50 psi when I first start it but dropps to about 25 to 30 while cruising at 3000 to 3500 RPMs after the motor is at the operating temp (180* thermo if needed to know) Drops between 8 to 12 at idle (750 RPMs) Sounds about right to me, and it got better after replacing the ORGINAL PCV valve, but I figured I'd ask the pros here. I have a pretty decent leak at the oil pan, I lose about a quart appox every 600 miles, and I'm getting the pan gasket replaced soon when I get the tranny rebuilt, hopefully within a month. I figured I would get the oil pump replaced if needed. As far as I know, it's orginal
__________________
Me ![]() 2000 Alero running 14's 2005 Nissan Altima (her's) 1967 Olds 330 motor sitting on a stand 1985 Delta 88 w/1968 350 rocket ( MURDERED )
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
Not sure if replacing the pump would improve your oil pressure all that much. I know they make "high pressure" oil pumps but isn't most of your oil pressure developed by the bearing clearances in the mains and rods? Your oil pressure sounds pretty good for an old engine. About the pcv valve contributing to the oil pressure, interesting. I thought the internal atmosphere pressure wasn't the same as the oil pressure. Hmmm, not sure.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#3 (permalink) |
^^ I didn't know the oil pump didn't contribute to the oil pressure.
After I posted it I re-read it and thought the same thing, for a 40 year old motor, oil psi is pretty good
__________________
#4 (permalink) |
Well, I really didn't say that. There would be no oil pressure if there was no pump to put the oil at the bearings to begin with, can't have oil pressure without a pump, but you won't have good oil pressure with old bearings either. In an old car, the reason for low oil pressure is probably going to be worn bearings.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Oil Pressure | slimer79olds | Small Blocks | 2 | March 25th, 2007 11:50 AM |
| oil pressure problems | airhead6969 | Cutlass | 1 | August 10th, 2006 12:00 PM |
| Loss of Oil Pressure | Run26.2 | Cutlass | 5 | August 10th, 2006 08:40 AM |
| 1966 400 oil pressure ? | TCR442 | Small Blocks | 7 | August 4th, 2006 08:48 AM |
| OIL PRESSURE | strtolds | Small Blocks | 0 | October 22nd, 2002 10:17 AM |
