Go Back   ClassicOldsmobile.com > Repair & Restoration > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 01-08-2008, 11:29 AM   #1 (permalink)
wagonman
Junior Member
freeze plugs?
Hello .I pulled an engine from storage and I noticed that one of the freeze plugs was rusted out.Motor turns by hand and is out of the car.What is the procedure to repair?Thanks.
wagonman is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 01-08-2008, 12:00 PM   #2 (permalink)
dynamic88
Senior Member
just pop the old plugs out and go to the auto parts store and get new ones to put back in. its kind of a pain in the ass if they are all rusty and stuck in there. you can get them out with a screwdriver and hammer. just work it back and forth from side to side . new ones just pound back in with a rubber mallet.
dynamic88 is offline   Reply With Quote
Old 01-08-2008, 12:09 PM   #3 (permalink)
wagonman
Junior Member
Thanks for the reply .Iwas wondering about if I had to flush it incase there was rust debris in the block?
Old 01-08-2008, 01:46 PM   #4 (permalink)
joe_padavano
Quote:
I wouldn't worry about it, though I would replace ALLthe freeze plugs with brass while the engine is out.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old 01-08-2008, 01:49 PM   #5 (permalink)
wagonman
Junior Member
Thanks.
Old 01-08-2008, 02:09 PM   #6 (permalink)
The_Jeremiah
Senior Member
yes definently replace them all, its like 8 bucks i think for the bag at the store, use a hammer and punch and hammer on one side to see if you can rotate the plug in place and pull it out with some pliers. If you accidently knock one into your engine, dont worry, just use a big screwdriver and your fingers to get it back to the hole, and grip it pretty tightly with some pliers and pull it out. you might want to use a little black rtv on the new plugs just to be safe. good luck
__________________
69 Cutlass 4 door. Built 350 inside, grandma's grocery getter outside. Best sleeper in disguise.
The_Jeremiah is offline   Reply With Quote
Old 03-06-2008, 04:37 PM   #7 (permalink)
1973cutlass442
Junior Member
freeze plug problem please help
i have a freeze plug question i have a 73 442 with the left side freeze plug missing i have bought the new one and was wondering how i would put it in with the motor still in the car theres not much room for swinging a mallot and ive tried to pull the exhaust header off but thats not goin to well i was hoping to not hav to do that if there is anyone that can help me with this problem that would be really helpful.
1973cutlass442 is offline   Reply With Quote
Old 03-06-2008, 05:00 PM   #8 (permalink)
J-(Chicago)
Seasoned beater pilot.
Hmm.....
Jack it up and take a wheel off maybe? At least you'll have a straight look at what you are messing with.
Sounds like a royal pain.
__________________
I'd rather have a numbers matching poker hand.
J-(Chicago) is offline   Reply With Quote
Old 03-07-2008, 06:49 AM   #9 (permalink)
joe_padavano
Quote:
This is often a problem. There is a rubber expanding freeze plug available that you can press in by hand and then tighten with a wrench. Not the preferred solution but an expedient way around the clearance problem.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
How do you get to those plugs? sbs4332 Cutlass 6 02-28-2008 02:25 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
