| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
Replacing valve cover gaskets
so my '69 cutlass (350) has leaking valve cover gaskets. the engine still runs well but im tired of the drips and smoke. my mechanic is askin more money than im willing to spend. ive never had to do this before and was wondering what id need to know to do the job myself. thanks for any advice yall can give
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Alero Chapter Secretary
Cork gaskets, and a lot of silcone (get the black stuff)
My gaskets came in the kit from Mondellotwister.com. I like the gaskets a lot and highly recommend them. Pull off the valve covers and undo any brackets that straddle the valve covers (back alt bracket) and remove the vavle cover by pulling straight up after undoing the bolts of course. I forget what size the bolts are, but you can get to them pretty easy O yeah, be sure to get all of the old gasket off first. If you don't it will leak again. I only did the job once, and it took me 1 hour |
#3 (permalink) |
Landyacht Club President
I prefer the rubber gaskets over cork, and make sure you don't overuse RTV. Also, you need to check the valve covers and make sure they aren't dimpled around the bolt holes. They sometimes get dimples in them because people over tighten them. If they are dimpled you can fit a socket around the bolt holes and flatten them out on a bench vise in your garage with a hammer. I usually adhere the gaskets to the valve cover with RTV and let it sit for a good long while before I put the valve covers back on the heads. This allows the RTV to act as a glue so the gasket doesn't fall of the valve cover when you put it in place.
#4 (permalink) |
Hot Rodder at heart Administrator
I taught him that....
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#5 (permalink) |
Junior Member
sounds good... and do i NEED a torque wrench or... if so what are the specs?
#6 (permalink) |
Seasoned beater pilot.
A torque wrench is always a good thing to use. It all depends on how much you trust yourself though.
A good local auto parts store will let you borrow one for a few hours for free with a deposit or a license. I believe the spec is 70 Inch LBs I don't know if they will have the seal breaker tool though.
__________________
#7 (permalink) |
Or you could use a 3/8 inch ratchet drive and just use your wrist to tighten them down, it doesn't take much as all you are doing is sealing down the gasket, whether cork, rubber or silicone sealant.
__________________
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| replacing lighter | GOLD72OLDS | General Discussion | 1 | October 17th, 2007 06:21 PM |
| Need stock type head gaskets | Deltarocket | Big Blocks | 4 | June 5th, 2007 07:54 AM |
| replacing starter | cutlassKing | Electrical | 2 | March 30th, 2007 02:06 AM |
| Valve cover gasket R/R | and1stp | Other | 3 | September 26th, 2006 05:43 PM |
| Need OLDSMOBILE ROCKET valve cover decals for 371 | J'ville | Parts Wanted | 5 | August 28th, 2006 06:21 PM |
