Go Back   ClassicOldsmobile.com > Repair & Restoration > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 11-09-2007, 06:51 PM   #1 (permalink)
ztim
Senior Member
307 start problem
It has been taking longer for the engine to start. It had been starting after two tries and now it is up to six or seven. This is only when it is cold. Once it starts, it is good for the day. Any ideas? Thanks
edit: it is a 307 from a '84 Delta 88.
ztim is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 11-10-2007, 05:10 PM   #2 (permalink)
J-(Chicago)
Seasoned beater pilot.
This has happened to me as well. That car should start on the first or second crank if everything is set up correctly.
Check all of your carburetor vacuum modules to make sure they are not going out. You must disconnect the vacuum line from them and pump them up with a vacuum gauge so that they move all the way backward or forward, and let them sit for a couple minutes. If the vacuum is still holding, they are functioning correctly.
Also, your timing is probably too far advanced. Make sure you unplug the battery terminals to reset the computer after you adjust the timing, so it can re learn.
yours is an 84, so you have more things to worry about breaking. Lot of vacuum lines and plastic t 's on that one. some of the plastic fittings even have 4 junctions
Check all of your vacuum lines for cracks. 1 at a time like spark plugs.
Your egr valve could be stuck open.
Check your thermostatic (THERMAC) for vacuum as well. It is that plastic thing in the back/bottom of the air cleaner.
__________________
I'd rather have a numbers matching poker hand.
J-(Chicago) is offline   Reply With Quote
Old 11-10-2007, 05:49 PM   #3 (permalink)
J-(Chicago)
You will probably have to get a few different size pieces of hose and several different size fittings to use the vacuum pump on all of the various parts.
until then ... give it 6 good pumps and then pump the gas as you are starting it.
__________________
Old 11-10-2007, 06:53 PM   #4 (permalink)
88 coupe
Junior Member
Before you do anything else, make sure the choke is working properly.
Remove the air cleaner, floor the gas once, and release it. If the choke is not closed, you have found your problem.
Norm
__________________
Quote:
Originally Posted by Texascarnut View Post
........ I think you are more of an irritant to everyone here, and most certainly not nearly as smart or knowledgeable as you seem to think you are.
88 coupe is offline   Reply With Quote
Old 11-10-2007, 09:04 PM   #5 (permalink)
Redog
Alero Chapter Secretary
^^ I second this
My choke was working backwards. It was open when I started the car, and would close when the car reached 195*.
Not fun pushing a 4000 lb car off the road. I had to jam a screwdriver in the choke levers on the side of the carb to start the car back up
Redog is offline   Reply With Quote
Old 11-12-2007, 01:36 PM   #6 (permalink)
ztim
Senior Member
With engine cold, I pumped the accelerator once and it closed. The hoses looked good although I haven't had a vacuum on them. A pump is on my list of things to acuire.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help! 1961 98 won't start Moofinator Ninety-Eight 8 06-04-2007 09:02 PM
Engine will not start D Appeldorn Electrical 4 04-24-2007 12:52 PM
click but no start dynamic371 Eighty-Eight 3 02-08-2007 07:45 PM
1987 307 problem..need help... falconsfan Cutlass 2 11-09-2006 04:54 PM
1987 307 problem...need help... falconsfan Small Blocks 22 11-05-2006 06:10 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
