Go Back   ClassicOldsmobile.com > Repair & Restoration > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Thread Tools Display Modes
Old 11-09-2007, 03:45 PM   #1 (permalink)
ChrisM
Member
Engine Knocking
My '73 Delta 88 350 engine knocks when I accelerate heavily and especially uphill. I have the timing adjusted correctly, but it still does it. I have heard that this may be because I us regular 87 unleaded gas. I have heard that these older engines require premium all the time because of compression issues or something. Is this true, because I really don't feel like paying for premium at the pump.
chris
ChrisM is offline   Reply With Quote
Sponsored Links
To remove this ad, register today!
Old 11-09-2007, 04:32 PM   #2 (permalink)
joe_padavano
Quote:
chris
By 1973, all Olds motors were low compression, so premium should not be required. Carbon buildup inside the cylinders will lead to increased compression and knocking, however. Check the timing again, and also have the balancer checked to be sure the outer ring hasn't slipped, thowing the timing off.
__________________
Joe Padavano
64 Jetstar 88 Conv
66 442 L-69 Conv
68 W-30
69 H/O
69 442
70 W-30
72 442
84 Custom Cruiser
86 Caprice wagon (w/307 Olds)
joe_padavano is offline   Reply With Quote
Old 11-13-2007, 01:25 PM   #3 (permalink)
ChrisM
Member
Thanks for the info! I will check the timing again and look into the balancer...One question though; where is the balancer located?
Old 11-13-2007, 03:43 PM   #4 (permalink)
Olds64
Landyacht Club President
The harmonic balancer is on the crank pulley. It is where your timing mark is located. You can double check your timing mark by kicking your engine over to TDC on the # 1 cylinder (hold your finger over the spark plug hole and crank the engine with the coil wire off). Then look for your timing mark next to your advance indicators.
Olds64 is offline   Reply With Quote
Old 11-13-2007, 03:53 PM   #5 (permalink)
ChrisM
Member
Thank you for helping me out Olds64. I will do all of that.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
how do you clean an engine and engine compartment? pinky Eighty-Eight 6 10-01-2007 11:24 AM
My 260v8 is knocking is it a rod or is it lifters? TennesseeDelta Small Blocks 2 03-27-2007 02:01 PM
engine & engine compartment colors Olds luvr Small Blocks 0 01-07-2007 11:42 AM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
