| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
Rebuliding an olds 350
I wanted some suggestions from all you guys out there that know the olds engine.. I got a 72 442 350 4bbl.. I would like to get high 300's - 400 hp.Its already bored out .30, I plan on getting it decked.. I just want some suggestions on what size cams to get, intake manifold, headers and all that stuff from you guys who build engines on a daily basis.
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Hot Rodder at heart Administrator
I don't build on a daily basis so I don't qualify to make any good suggestions but I do want to welcome you to our site. What you have for a goal is attainable but I would suggest to watch how high you make that static cr since gas is high as a kite and it is hard to find good high octane fuel in many places.
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. Last edited by Oldsguy; October 7th, 2007 at 08:52 PM.. Reason: spelling correction |
#3 (permalink) |
Landyacht Club President
I think you should put a K&N air filter on it. That would give you a good HP boost.
Actually, I know little about building engines, but welcome to the site. |
#4 (permalink) |
Super Moderator
Once again, I'll caution against the K&N and similar filters. The reason they flow more air is because they let more dirt through. Many, many tests have been done that show increased engine wear when using these filters. I'd recommend frequent changes of AC filters.
__________________
Joe Padavano 64 Jetstar 88 Conv 66 442 L-69 Conv 68 W-30 69 H/O 69 442 70 W-30 72 442 84 Custom Cruiser 86 Caprice wagon (w/307 Olds) |
#5 (permalink) |
Seasoned beater pilot.
I'm with Joe on this one. I put a k&n on at 40000 miles and was rebuilding the carb at 80000. After that I went back to stock, and now I'm at 143000 miles with no troubles at all. Change it when you change the oil. I bought 15 filters at 3 or 4 bucks a pop a few years ago.
__________________
#6 (permalink) |
as far as builds go, you'd be better off looking at hod rod magazine's various builds. they always have a lot of info on what they did.
And when you're bored check out this Dick Miller build. http://www.popularhotrodding.com/eng...ler/index.html
__________________
Last edited by J-(Chicago); September 29th, 2007 at 12:10 PM.. Reason: xinsert hyperlinkx |
#7 (permalink) |
Olds64 was kidding, but I think you all knew that. He has been doing that since he was a kid..........wonder where he got that from???
__________________
Dan '77 Cutlass Supreme '46 2 door "The rocket 455.....it's a sledgehammer approach to a thumbtack world" LuxBlue of HAMB. |
#8 (permalink) |
Alero Chapter Secretary
Rebuild a 350 for 300 to 400 HP?
Easy New Cam (.496/.512 is the hiest I'd go for street) Dual Plain high rise manifold (Edelbrock makes a nice one) 750 CFM carb (to feed that hungry engine) new pistons (12.1 CR pistions for BB heads) new rods (stronger) new rocker arms (need with new cam) new pushrods (need with new cam) stainless valves (Lighter) 3 angle valve job big block heads, .010 milled (Bring CR down from 79 or 80cc back to 69 to 70cc) headers (helps move exhaust) x pipe dual exhasut (Proven to make more power than true dual) chambered mufflers (Proven to make more power than staigth thrus) electric fan (reduces drag on motor) also doesn't hurt to have tranny cooler 2000 to 2500 torqure convertor tach oil pressure gauge |
#9 (permalink) |
I read/witnessed a really nasty thread over at another site where about five guys argued to the "end of the world" about whether electric accessories like fans and water pumps would put more drag on an engine than their mechanical counterparts. The sad thing, not a single person was an electrical engineer or a mechanical engineer nor had any scientific measurements or proof to back up their respective claims. It got down to name calling and flaming and nobody benefited from the entire thread. Except to know who to avoid in future threads.
__________________
#10 (permalink) | |
Super Moderator
Quote:
__________________
#11 (permalink) |
Junior Member
I ordered some parts last week.. I got the edelbrock performer rpm intake, comp cam .496/.520 ,new magnum rocker arms with forged pushrods, 650 holly carb, hooker headers, going with a 3 angle valve job port and polished
#12 (permalink) |
^^ That will help you out a lot
#13 (permalink) |
Junior Member
how rough of an idle is that??
#14 (permalink) |
Should still be "streetable" and will have a nice "lopy" idle
#15 (permalink) | |
Tom Servo's Stunt Double
Quote:
You simply can not beat a well-built QJet. I ran a 650 Ebrock (squarebore like a Holley) and it did not outperform my QJet...except in wasting a lot of gas in town. The QJet gives you streetability and raceability and can be pro-built for much less than a new carburetor that won't perform as well. BTW, that's a great cam. Nice lope (if you care about the sound). You can run power brakes and AC with it and still kick some major @ss when needed. Just my experience....your mileage may vary. C.J.
__________________
Dad said, "Sometimes you read Job...sometimes you ARE Job!" ![]() Last edited by texasred; October 5th, 2007 at 03:02 PM.. |
#16 (permalink) | |
Quote:
#17 (permalink) |
Junior Member
i'll try to post up some pics of the car and parts i got
#20 (permalink) |
Nice car!
Don |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1970 olds 98 350 | KoVaC | Cars For Sale | 5 | December 3rd, 2007 07:55 PM |
| Looking for an Olds 350 | Redog | Parts Wanted | 3 | March 26th, 2007 07:49 AM |
| Flywheel cover Olds 350-turbo 350 | Jokers69 | Parts Wanted | 1 | October 5th, 2006 04:00 AM |
| olds 350 problems | <lunatic> | Big Blocks | 10 | January 6th, 2005 08:21 PM |
