| Forums | Gallery | Encyclopedia | Tech | Olds Junction | Register | All Albums | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars |
| Welcome to Classic Oldsmobile Forum! |
Welcome to Classic Oldsmobile forum, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today! |
Thread Tools | Display Modes |
#1 (permalink) |
Junior Member
carb ?'s
My freshly rebuilt 4barrel roch. is still giving me problems,not sure if it's a vacuum leak or carb just not getting enough fuel.If i pour gas directly into fuel bowl or down barrels it will start and rev really high.Other than that she won't start.where should i start to look first?novice
| Sponsored Links |
Register your account for free today or log in if already registered to remove this ad! |
#2 (permalink) |
Landyacht Club President
If the carb is the only thing you have changed then make sure your idle mixture screws are backed out 2.5 turns to start out with. That is a good starting point for Quadrajets. You also need to set the choke with the car cold. Make sure the carb is tight against the manifold, and double check your vacuum ports and make sure if there are any you aren't using they are plugged. Hopefully that will get the car started and you can tune it from there. Good luck.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| best carb????? | troys2222 | Small Blocks | 0 | April 18th, 2007 03:29 PM |
| Carb Question? | punishercarr | Big Blocks | 4 | April 16th, 2007 07:28 AM |
| Carb questions | American Lead | Small Blocks | 6 | March 11th, 2007 07:32 PM |
| Carb suggestions | 66starfire | Big Blocks | 8 | December 27th, 2006 10:10 AM |
| w32 carb | Chuck C | Big Blocks | 5 | April 11th, 2005 11:48 AM |
