ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old August 21st, 2007, 05:48 PM   #1 (permalink)
joninva1
Junior Member
A real challenge - Block ID issue
I have an engine with no car to be able to help identify it by.
I have learned that the engine was originally in some sort of Oldsmobile.
I was able to narrow this enigne down to being an Olds thanks to the manufacturer of the exhaust manifolds that are on the motor having a corresponding part number.
Behind the water pump the only code I see is 6509GM5.0LG.
I assume that it's a 1965 September 5 liter. ?? they made a 5.0 in 65?
There was one more number slopily punched into the block to the left of the number mentioned above. It reads 174182. That's it.
Viewing the top of the engine on the intake manifold the firing order is 18436572. The intake manifold also says 5A on it with it's own casting number being 22526212.
The oil filter is on the passenger side rear and bottom. The starter motor is on the driver side rear and bottom. The distributior is on the rear of the engine. The oil filler neck is on the front and top of engine more on the passenger side.
I can provide as much info as any one needs. If you need more data feel free to ask, but there aren't any other identifying numbers that I can see on this engine except what is on the intake manifold gasket but I have been referencing that number and I think it was provided with the marine cooling system that's installed on the engine. I have a ton of pictures of this engine too.
If you want to boost your ego- it mould help me out a lot too with getting this beast running and wired.
Feel free to e-mail me- notacountryboy@hotmail.com.
I can also e-mail you high res pictures with great detail of this engine if you would like.
any info would be awesome. it's really become somewhat of a puzzle. I get clues here and there- hopefully one day I can figure this thing out. Hopefully before it gets too cold to take the boat out.
Thanks,
Jon
joninva1 is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old August 22nd, 2007, 10:29 AM   #2 (permalink)
Redog
Alero Chapter Secretary
Redog's Avatar
6509 GM 5.0L
It's a 1987 307
Redog is offline   Reply With Quote
Old August 23rd, 2007, 08:09 AM   #3 (permalink)
joninva1
Junior Member
That's amazing! how did you pull 87 307 from 6509GM5.0LG?
I was doing some more research and found the engine to be an Olds 307, 85-90 based on the intake manifold casting number (something which was well hidden behind the Edelbrock and I also had wrong in my post by a digit.
Well this day has turned out to be a good one so far!
Thanks!
Old August 24th, 2007, 12:57 AM   #4 (permalink)
Redog
Redog's Avatar
I have the Mondello book
Old August 25th, 2007, 09:28 AM   #5 (permalink)
joninva1
Junior Member
Lucky. Thanks again. I reeeeeely appreciate it.
Alot.
I feel like my life can go on now... It has been such a headache so far with not knowing what that engine was.
Does that book say what compression the engine should be putting out?
Someone trashed all my Chiltons that covered this motor... :-/
Old August 27th, 2007, 05:03 PM   #6 (permalink)
Redog
Redog's Avatar
I think it's 8.2 to 1 I know that's what the '85 put out
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Is it live or is it memorex??? or a real 442 70vette 442 18 September 3rd, 2009 10:47 AM
Valve train issue? TWS Big Blocks 4 January 10th, 2009 03:50 PM
Is this 442 for real??? catonine 442 2 July 20th, 2007 07:42 PM
Its a real 442?? 442 Guatemala 442 6 July 12th, 2007 11:54 PM
T-top rust issue shaggy Chassis/Body/Frame 1 April 5th, 2007 06:06 AM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
