ClassicOldsmobile.com Oldsmobile Enthusiast Community
Go Back   ClassicOldsmobile.com > Repair & Restoration > Engine & Transmission > Small Blocks
Forums Gallery Encyclopedia Tech Olds Junction Register All Albums FAQ Members List Calendar Search Today's Posts Mark Forums Read Used Cars
Welcome to Classic Oldsmobile Forum!
Welcome to Classic Oldsmobile forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Classic Oldsmobile Forum today!
Thread Tools Display Modes
Old August 2nd, 2007, 05:44 PM   #1 (permalink)
77 oldsMAbrotha
Toliver
3A heads
Are stock 3A heads worth sending to the machine shop if trying to build up a '77 350+ hp motor with 9.5:1 compression?
At the moment 750 carb, rpm intake, and dynomax headers would be working together with the machined heads.
?In your opinion?
If the heads can perform, then...to the machine shop!
77 oldsMAbrotha is offline   Reply With Quote
Sponsored Links
Register your account for free today or log in if already registered to remove this ad!
Old August 2nd, 2007, 07:53 PM   #2 (permalink)
don71
feed the pig
don71's Avatar
Those heads are poor on the exhaust flow compared to older heads. I have heard they are a thinner casting in some areas, but can't confirm that.
You have better choices in the 5 6 7 castings and even the 8s are better than the 3A, as is. So, yea try to find another set.
But in all honesty, If I was on a budget and had a good set of 3A heads, with nothing else stopping me......I'd run'em. Oldsmobiles are more fun when they're running .........than sitting around waiting for whatever.
__________________
1971 Cutlass S Holiday coupe-455/th400 3.23
Oldsmobile they were meant to be driven.
don71 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.0.0
All content Copyright © 2008 by Internet Brands, Inc.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63
