How to measure belt length?
Old May 2nd, 2011, 04:45 PM
defiant1's Avatar
Question How to measure belt length?
Moved alternator to other side of motor. Now original belt is too short. What is the most accurate way to measure the belt length around the pulleys? Wire, string, etc.?
Granted the alternator is adjustable so I have room for error but would like to get it close as possible.
d1
defiant1 is offline
Old May 2nd, 2011, 04:59 PM
citcapp's Avatar
I cut a too long used belt and put it around the pulleys and then measure it. This has always worked well for me
citcapp is offline
Old May 2nd, 2011, 06:01 PM
defiant1's Avatar
Ok, I'll see what I have laying around. I got plenty of serpentine, but not sure of v-groove.
defiant1 is offline
Old May 2nd, 2011, 06:09 PM
defiant1's Avatar
I think I am overthinking this...
Since I am mounting the alternator on the driver's side with the bracket and brace for a 1970 Cutlass what part # belt do you all use? I have an A/C (aftermarket) car and instead mounting the alternator to the drivers side, they mounted it under the A/C.
So, I am assuming that the alternator belt goes around the crank pulley and around the fan belt pulley and finally around the alternator pulley (one big oblong circle). If that is correct, then I should be able to order the "factory" belt?
If anyone has a part number, I would appreciate it.
d1
defiant1 is offline
Old May 2nd, 2011, 07:33 PM
Here are pics of the driver's-side-alternator belts for a '70 Cutlass...
350:
455:
The GM numbers you're looking for appear to be
391213 without P/S or 406086 with P/S for a 350, or
399628 with or without P/S for a 455.
You should be able to cross reference them in any auto parts store book - Dayco, Gates, etc.
Sizes can be found here:
MDchanic is offline
Old May 2nd, 2011, 07:52 PM
defiant1's Avatar
Eric, thanks for taking the time to post this info. I imagine, not only will it help me but others as well.
Shaun
defiant1 is offline
bassinguy
March 21st, 2014 02:01 PM
coldfire
Wheels and Tires
July 22nd, 2013 05:49 PM
Olds98
August 6th, 2010 05:02 AM
DAN76
July 30th, 2009 05:53 AM
Sixoh
August 21st, 2006 07:50 AM
Quick Reply: How to measure belt length?
