Stripped quadrajet carb fuel gas inlet 1971 Cutlass
Old February 24th, 2011, 04:45 PM
jpaulwhite's Avatar
All,
I thought I was just doing a basic wrenching job. Had to be to work at 9. It was 8:00. I figured I'd pull the fuel filter and replace real quick. Well surprise and unknown to me, the guy who had the car before me had stripped the carb fuel filter inlet threads and glued/JB Welded or something'd the fuel filter into the carb.
So I bought one of those self tapping fuel filter fittings. Last Friday I rode down to Winchester to buy one. 3 hours and $40 worth of gas later I found out it was the wrong size. I bought the 1" diameter one, but I needed the 7/8"
So then I went ahead and ordered this one from quadrajetparts.com. I ordered it on Saturday night or maybe Sunday and got it yesterday. Great work!Tomorrow or Saturday I'll run out and throw it on.
jpaulwhite is offline
Old February 24th, 2011, 05:55 PM
Lady72nRob71's Avatar
Sorry to hear about the bad luck...
Happens to me at times, too.
I hope this one will do the trick!
Lady72nRob71 is offline
Old February 24th, 2011, 07:21 PM
GM Enthusiast
OLD SKL 69's Avatar
I had the same problem with the carb on my 71. I had a carb place helicoil in new threads and it allows me to still use the carb fuel filter. (Cost @ $80) The self tapping ones do work fine, but I would probably use an inline filter so that you did not have to take it apart again.
OLD SKL 69 is offline
Old February 24th, 2011, 07:59 PM
One of None W-31
71 Cutlass's Avatar
X2...I like the inline filter idea.
71 Cutlass is offline
Old February 25th, 2011, 02:15 AM
jensenracing77's Avatar
if this is a rare carburetor, i would have a heli coil put in it. if for some reason this one leaks i don't think you can fix it a second time.
jensenracing77 is offline
Old February 25th, 2011, 05:25 AM
Inline filters are okay as long as they are on the suction side of the fuel pump. I do not like rubber hose on the pressure side (despite the pressure being rather low).
63super88
September 17th, 2019 01:48 PM
68442Convertible
February 22nd, 2015 06:17 PM
yeahbuddy
August 8th, 2013 07:10 PM
yeahbuddy
July 8th, 2012 09:26 PM
Giddy
September 16th, 2011 07:12 AM
Quick Reply: Stripped quadrajet carb fuel gas inlet 1971 Cutlass
